Old 04-26-2013, 10:38 PM   #1
Ripsaw
Drives: 2012 Yaris LE
Question Towing my Yaris
I'm going to be towing my Yaris automatic with a tow dolly behind my motorhome. Should I put the transmission in park or drive? Thanks
Ripsaw is offline   Reply With Quote
Old 04-26-2013, 10:46 PM   #2
Kar98
Drives: 2011 Scion tC
I would think neutral?
http://www.yarisworld.com/forums/showthread.php?t=23352
Old 04-26-2013, 10:55 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
front wheel on the dolly and it can be parked, it is the rear wheels that are going to be rolling, just don't put the parking break on.
Old 04-26-2013, 11:01 PM   #4
If you are towing it on a dolly, the rear wheels will be in contact with the road and the fronts will be lashed to the front wheel pockets. You don't want it to come off the dolly, so it makes sense to prevent movement against the straps by putting the tranny in park. Just make sure you do not put the ebrake on.
Old 04-27-2013, 12:03 AM   #5
jayeh
Drives: '08 Yaris LB
Can MT Yarises (or corollas for that matter) be towed 4 wheels down? I'm fairly certain AT ones can't but I've seen some local transporters using an Echo and/or Corolla towed 4 wheels down.
jayeh is offline   Reply With Quote
Old 04-27-2013, 12:46 AM   #6
MT's are fine to tow with all four wheels down (in neutral). AT's should never have the drive wheels in motion unless the engine is doing it.
Old 04-28-2013, 11:05 AM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I would never do it, because at least on the old mechanical odometers, that mileage, even with the car completely off, added to the total.
Colin Chapman disciple
Old 04-29-2013, 11:27 AM   #8
Idahotom
Drives: 2008 5 sp. LB
I wondered that also....I don't tow my Yaris, but I do tow my '99 Rav4, all 4 wheels down. It has a digital odometer, and I need to have the ignition switch in ACC. to keep the steering from locking up. My guess is (havn't bothered to check, don't really care) the digital speedos don't work unless the engine is running?
Idahotom is offline   Reply With Quote
Old 04-29-2013, 12:04 PM   #9
with the ignition off it will not increment, but with the ignition on and the engine not running it will.
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
Towing Hitch for a Yaris fmicle General Yaris / Vitz Discussion 1 05-16-2007 08:07 PM
