Old 07-21-2013, 04:12 AM   #163
WestCoast
Drives: yaris
Actually, my CN2 details as below:
(-) 250mA Output to Starter-Kill Blue 1
(-) Parking Light Reminder Orange/Black 2
(-) 250mA 2nd Parking Light Output(POC #1) Green/White 3
(-) Emergency Brake Input Light Blue 4
(-) 250mA 2nd Starter Output (POC #2) Red/Black 5
(+) Foot Brake Input Light Blue/White 6
(-) 250mA 2nd Ignition Output (POC #3) Green 7
(-) Trunk Trigger Input Violet/Black 8
(-) 250mA 2nd Accessory Output (POC #4) White/Black 9
(+/-) Door Trigger Input Red/White 10
(-) 250mA Status Out(GWR) (POC #5) Black 11
(+/-) Key Sense/Glow Plug Input Brown/White 12
(-) 250mA Rearm Output (POC #6) Orange 13
(-) Slave/Timer Start input Pink 14
(-) 250mA Disarm Output (POC #7) Orange/White 15
Engine Sensing Input (Alt./Tach/Battery) Yellow/Black 16
(-) 250mA Horn Output (POC #8) White 17
(-) Hood Pin Input Gray/Black 18
(-) 250mA Aux1 Output (POC #9) Violet 19
(+) 12V Output to Siren Brown 20
I only need remote start my car, and remote lock and unlock my car, do I need connect all of these cables or just some of them. It's really hard for me to find the right connecting place.
WestCoast is offline   Reply With Quote
Old 07-21-2013, 07:20 AM   #164
Starter kill is an optional one that requires an extra relay and is documented in your remote starter's manual. You end up cutting the black starter wires on the ignition switch connector and connecting the relay in between.
Parking light output, foot brake, 2nd Ignition output, and Tach input are all in my guide.
The hood pin will be documented in your manual, as it is simply a pin switch that requires you to drill a hole to mount under the hood. It doesn't get connected to any of the car's wires.
Old 07-21-2013, 08:08 PM   #165
WestCoast
Drives: yaris
Hi CTScott, I have tested my +12V parking light(green pin 29), but the meter read is 0, and the -12V parking light(white pin 13) is 12V. What I can do?
My CM6200 need input is +12V.
Thanks in advance,
Old 07-21-2013, 10:29 PM   #166
Thanks in advance,
Parking light is not an input, it is an output, so your device will output +12V to pin 29 to flash the lights.
Old 07-22-2013, 02:52 PM   #167
WestCoast
Drives: yaris
Good to know, and where is the Emergency Brake pin in my 2007 auto transmission yaris?
Old 07-22-2013, 03:02 PM   #168
The yellow wire at the base of the ebrake lever or the yellow wire in pin 4C-2. The ebrake is typically not required for remote starters, except for with manual trans.
Old 07-22-2013, 06:26 PM   #169
WestCoast
Drives: yaris
Do my auto trans car still don't need the Door Trigger input for my remote start?
Old 07-22-2013, 07:05 PM   #170
Check the manual for your remote starter. Most do not require that, as they can be used with cars with manual locks.
Old 07-22-2013, 07:30 PM   #171
WestCoast
Drives: yaris
Where to output my (+) 12V Siren if i my car don't have the arm system?
Old 07-22-2013, 09:54 PM   #172
Unless you are adding a siren you won't need to connect that.
Old 07-23-2013, 03:22 AM   #173
WestCoast
Drives: yaris
My CM6200 said I need cut the green loop wire inside the brain module, but I can't find it, where is my green loop wire?
Old 07-23-2013, 07:00 AM   #174
It is inside of the remote starter, not a wire on the car.
Old 07-23-2013, 01:20 PM   #175
WestCoast
Drives: yaris
Thank you so much CTScott, I found it after I opened the CM6200 module.
Now, the wires have been connected, and I have tried to lock and unlock the door, works great.
When the car was running after I take off the key, I still can use remote start to shut it off. But the weird thing is, after I push the remote start button to start my car, the car just flash twice, then nothing happen, however the car will immediately start after I plug in the key without turn the key(just in the lock position even not in the ACCE or ON position).
Old 07-23-2013, 02:54 PM   #176
I have only installed a remote starter on a Yaris which has the engine immobilizer and therefor required the key bypass module. It sounds like even though yours does not have the immobilizer that the ECM wants to see the "unlock warning switch". It is a 2 pin connector on the ignition switch with a yellow and a white/black wire. As a quick test, just jump the yellow to the white/black by shoving a piece of wire in the back of the connector. If it remote starts with that jumped, then you will need to hook the yellow wire to the start #2 output of the remote starter.
Old 07-23-2013, 07:55 PM   #177
WestCoast
Drives: yaris
You are the amazing man CTScott, I never done this before, but every thing works great now.
Old 07-23-2013, 09:48 PM   #178
Nice! I am glad to hear it is done and working.
Old 08-12-2013, 02:20 PM   #179
Originally Posted by Nadial View Post
Hi guys,
First off, great forum, I have searched for a couple of days and found all the wires (even how to wire throught the firewall ) for my DIY alarm install on my 09 two door hatchback, or so I thought.
Surely this is a noob question, but I cannot get the parking lights to flash. My sp-101 manual depicts two (white) 12v flashing light outputs (7.5 amp x 2).
I have tried:
Connecting one white wire to pin 13, parking light (-), on the 13-pin plug by the headlight switch without success
Connecting one white wire to pin 29 (green wire), parking light (+), on 30-pin plug 4A in the dash fuse box without success.
I have tried alternating the two white wires in both positions as well.
It might bear mentioning the the the 12v power input is connected to the gray wire, pin 5, on the 8 pin plug by the ignition swith. Which is supposed to be constant 12v.
Thanks in advance
If you have a green wire in your headlight switch connector, in place of one of the white/black wires, then you would have to use the Pin 29 + connection, instead of the pin 13 white connection.
Check the 10A TAIL and 7.5A PANEL2 fuses in the fuse panel that is under to bottom of the dash to see if you popped one of those fuses. If you connected to - output to pin 29 you would pop it.
Old 08-12-2013, 03:56 PM   #180
The 10A tail is fine, there is no panel 2, only a 7.5A panel 1 beside the 10A tail, and it is fine.
This is what I have for the headlight switch connector
Sorry I had to use a picture from another forum, best I could do in short notice.
I tested the connection for continuity.
The one thing I noticed is that the left front parking light (inside the headlight assembly) is burned out.
Thanks
OK. In that case, if you simply jump the white wire to one of the white/black wires (you can use a paper clip or piece of wire to do so, you should see the tail lights come on). This would do the same thing as the parking light - output on the remote starter.
If you do, then something is not configured correctly with the remote starter or the connection to that wire is not good.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 02:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
