![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Apr 2009
Car wash blew off car roof rubber strips...
So I took my Yaris through a local car wash yesterday and it has one of those industrial blow dryers at the end that blow your car dry. Well when I got home I noticed the two rubber weather strips on the roof of my car were completely dislodged and I have to assume it was the car wash blow dryer since it wasn't like that before. The strips are still there, they just won't go back into place anymore, they're all loose now.
Has this happened to any of you? How do I fix this? Are the strips glued down? Any ideas on how much it would cost for the dealership to replace or how much the part is so I can do it myself if it's possible? Never going through a car wash again.... |
They are easy to replace, as they just snap into their track. If yours won't go back on, the tabs may have been ripped off.
I can definitely see the car wash dryer catching it just right to pop it out of place. They are about $40 each from the dealer: Left or right: 75551-52130
Mr. 155 and climbing
Just use some 3M two sided tape and stick them back down.
After having a second look this morning, it appears that the tabs at the ends are still there because it's still in place at the ends and they won't come out:
![]() However, the rest of the strip in the middle is loose fitting, in fact, I can actually pull it up like this: ![]() ![]() Is that normal? Is it supposed to snap back into place in the middle parts or just the ends because I can push the middle part back down but it's not like super snug, only the ends seem to be snapped down and snug? |
Start at one end and work your way to the other pushing firmly.
I tried that and while the middle section does go back down into place, it's just loose fitting, not very snug. I'm wondering if that's normal or not.
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Go to the parts store and get some "automotive trim adhesive" a DAB here and there will do the trick.
Use caution as the adhesive tends to be messy and dries yellow... I had the exact same issue caused by the same thing.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
#9 | |
They tend to stretch once removed, to where they don't sit very well when put back on. Adhesive might not be a bad idea to get them to sit correctly without spending $80.
Yes. This has happened to me a couple of times. Mine still just snap back down though.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
Same here.
Are those roof strips actually for weatherproofing or just for show? I don't want water to leak into the cabin or rust to form in the groove where the strip goes.
I'm gonna go have another look and see if I can somehow find a way to clamp it down into place real snug. I'm wondering why Toyota didn't use adhesive on these things in the first place? |
#13 | |
#14 | |
2ZR swap. DO IT! Ask how!
#15 |
OK, mine finally gave up the ghost today (thanks again to the brutal southcentral Texas sun and heat!). Did anyone find these at a reasonable price?
Cheers! M2
#16 | |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 05:36 PM |
| Regular car wash, or Dealer car wash? | Buckethead | Wash, Wax, Detailing, Exterior Repairs | 49 | 07-21-2007 01:46 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 11:58 PM |
| About hand wash and other methods.... | zyovka | Wash, Wax, Detailing, Exterior Repairs | 5 | 09-27-2006 06:10 AM |
