Old 01-23-2014, 02:40 AM   #1
Leonard_Church
Drives: 2007 Toyota Yaris Sedan Silver
Cable driven throttle body on 2007 1NZ?
I did an oil change on a scion with the 1NZ the other day and they had an analog throttle body on it and was wondering if anyone had thought of converting their yaris to the same layout and, if so were there any codes being thrown about it? I'm not a fan of ETB's and much rather the old style throttle bodies.
2007 Yaris sedan 1.5 1NZ-FE With 5 speed Manual gearbox. Running a set of 205/45/R16
Leonard_Church is offline   Reply With Quote
Old 01-23-2014, 07:52 AM   #2
To do so requires standalone engine management, in place of the ECM, as the drive by wire throttle is a key input (via a dual circuit) to the ECM and without it being present the ECM will not feed the injectors. On Garm's turbo Yaris he had done the cable throttle, but he was running standalone management.
With the stock ECM the only way to make it work would be to feed the ECM a pair of fake accelerator pedal sensor signals relative to the throttle position sensor on the throttle body. This is doable, but would require some development to do.
Old 01-23-2014, 12:20 PM   #3
+1 - won't work without changing using a standalone ECU.
Old 01-23-2014, 02:56 PM   #4
Leonard_Church
Thanks for the response guys. Guess I'll stick to the fly by wire system then.
Old 01-25-2014, 02:24 PM   #5
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
I've thought about making my yaris think it is a toyota echo.....convert to throttle cable and non-abs brakes.
What all does the ecm control? ...what would you loose if you ran a yaris with the echo ecm?
Old 01-25-2014, 04:45 PM   #6
The Echo is not CAN based, so you would have issues with the power steering, body ECU (door locks if equipped, door open status, etc.), and instrument cluster if you switched to a Echo ECM.
If there is enough interest and a commitment to the interest, I would be willing to develop the interface necessary to allow a cable throttle to work with the stock Yaris ECM.
Old 01-25-2014, 05:04 PM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I thought that there had been some development along these lines, but the TPS conversion was found to be unfeasible. Perhaps I'm mixing up something else?
At the moment, the only benefit of drive-by-wire that I can see is automatic idle adjustment to prevent stalling when creeping/cruising at low speeds without having to ride the clutch. Granted, I'm OK with lots of clutch action to regulate it myself, but a more aggressive spring plate may be in my near future and that could become a nuisance. I suspect that the DFCO jerk would also become much more pronounced when slamming the butterfly closed, no?
Either way, I'd love to participate in developing/prototyping this system.
Old 01-25-2014, 05:14 PM   #8
bronsin
bronsin's Avatar
That would be a blessing. I cannot BELIEVE manufacturers have gone to the wire actuated system given its obvious problems. It does not give positive throttle control. In tight manuvering situations this could cause an accident.
I can think of traffic situations where it could cause an accident.
That the government, with all its "safety" laws like airbags, ABS etc hasnt made the manufacturers stop making an obviously defective feature is hard to understand.
No wait I do understand it. The government is an IDIOT!
Old 01-25-2014, 05:43 PM   #9
Flipper_1938
I'm pretty sure it all has to do with stability control. The car has to have the ability to over-ride driver inputs.
Old 01-25-2014, 05:53 PM   #10
tk-421
tk-421's Avatar
Drives: 5D-07-LB
How different is a cable-driven throttle to a DBW with a throttle controller? I think the latter is better because I get to tweak the sensitivity depending on traffic conditions...
Old 01-25-2014, 06:53 PM   #11
bronsin
bronsin's Avatar
All I can say is drive an ECHO. It doesnt need tweaking.
Old 01-25-2014, 06:57 PM   #12
bronsin
bronsin's Avatar
Hmm interesting.
That takes us into a whole another thing.
We are being convinced we dont know how to drive!
And of course once the powers that be convince us of that, they get a big payday!
Yeah!
Hey give my my $100,000 I dserve and I'll go along with it.
Seriously rear view cameras do anything for safety? I mean shouldnt you look behind you and proceed cautiously?
Also it if frequently the front wheels that run over kids with the car backing up. They will run around spastically like kids do out of the picture of the camera.
Old 01-25-2014, 07:02 PM   #13
Flipper_1938
I liked my Echo much more than I like my Yaris.
Old 01-25-2014, 07:19 PM   #14
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Man, I totally understand...
I went from a cable operated throttle body on my 1996 Tacoma (just like the Echo) to the drive by wire on my 2012 Tacoma and the difference is night and day. I really miss the immediate positive linearity of the old cable system. And it was immediate in both directions on and off the pedal.
Greg
Old 01-25-2014, 07:22 PM   #15
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That doesn't really answer my question, though... Have you tried a throttle controller on your Yaris yet?
Old 01-25-2014, 07:53 PM   #16
tk-421
tk-421's Avatar
Drives: 5D-07-LB
My throttle controller really minimized the lag to the point that it's basically imperceptible... Plus I get to increase said lag to help with fuel economy when the tank's almost empty.
Don't get me wrong, I'm all for trying out new things... But is it really better not to have the option to adjust throttle response based on different conditions?
Old 01-25-2014, 09:28 PM   #17
bronsin
bronsin's Avatar
Oh no I havnt.
Im strictly a stock owner.
No springs, mags, turbos or sway bars for me!
Old 01-25-2014, 09:53 PM   #18
tooter
play every day
tooter's Avatar
Does it also minimize the lag when you let off the throttle? Do the revs drop off quickly? I might go for one if it did that.
Greg
Tags
body, cable, electronic, thottle
1.8L throttle body dimensions drawing CrankyOldMan DIY / Maintenance / Service 5 03-09-2016 10:30 PM
Cable throttle body Crazy Butcher Performance Modifications 23 01-24-2013 01:31 AM
Throttle Body spacer? jekqmb Performance Modifications 2 10-05-2011 12:02 AM
