#55 |
Got them put on earlier . Set 34 , will put to 35 or 36 . They were $72 and the $50 rebate will put them at $59.50 . That's if the rebate is approved . Will try to drive it tomorrow . If , will get gas . Wonder if it's now the winter blend .
#56 |
![]() ![]() Drives: White Yaris Sedan Join Date: Mar 2014
Fantastic, I've just got my General RT43's installed today as well, however the tech pointed out that I had a bent steel rim but I think it should be ok.
#57 |
Nice . Not so for the rim . Hopefully they'll be what Tirerack and others claim them to be . If not , can live with the low cost .
#58 | |
![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
My bad, I've actually got toyo observe G-02 plus. Nonetheless, a great tire. Sorry for the mix up.
![]() TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges... |
#59 |
Start of new tank with the RT 43s' at 35.5 p.s.i.. 2 of us , groceries ( 80lbs.?) , a very steep hill , mid 40s' and winds of 20+ . This is SUNOCO 87 w/ E10 which could be a winter blend . The '11 base model with the auto is averaging little over 37 and that has Bridgestone Ecopia EP 422's at 35 .
#60 |
The ride quality on my RT43's is really smooth, not that quiet but it could be the car and not the tires itself. The mpg seems about 1-2 miles better. I'm really happy with them so far and I'll post some pics later. Also, at what PSI do you keep your tires on? Toyota recommends 32 PSI for front/back, however some users put more than that.
#61 |
Good to know you're enjoying them . All set at 35.5 . Here's the latest gas mileage . Just me going out for pet food and other stuff . Includes 30+ miles on interstate and some city driving .Very windy . Was at 39.1 until the stop signs and stop lights .
#62 |
This is the start of a new tank of the '11 base FIT with a 5 speed auto . Have Bridgestone Ecopia EP 422s' on it at 35 p.s.i.. Will try to do same route with the '13 with the RT 43s' to see if I can get same results .
#63 |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
i know here in MI we start getting the winter gas in early October, and when I lived in CT it seems it was around the same time
#64 |
Called the gas supplier and the winter blend delivery started 10/1 .
#65 |
This is the current gas mileage with the RT 43s' . The better 1/2 drove it today and yesterday . Mornings have been in the low 40s' and there's a 2+3/4 climb up a steep hill thanks to being in a valley . It also has been very windy , gusts up to 30 . Hopefully it's close to the display or above . Might be about 300 miles on them and are around 35 p.s.i..
#66 |
She drove back home in the rain on the interstate and state roads with ease . Didn't feel insecure with the RT 43s' . They now have over 500 miles on them . The '13 display is showing 37.7 and the '11 is 37.4 . They may be doing as well as the Ecopia EP 422s' a L.R.R. tire .
#67 |
'13 base FIT w/ 5 speed auto : 2nd tank with RT 43s'. Encountered many hills , wet roads , cooler temps and gusty winds . 25% city . Sure winter blend taking a part too .
#68 |
Noticed that the General Altimax RT43 H-rated tire has deeper siping than the T-rated . So , those considering the RT43 may want the H for areas that have plenty of snow , ice , etc.. The T's for milder winter or none . I would think that the H has less of a tread life due to the deep sipes . The T may give slightly better gas mileage with shallow siping
#69 |
Treadwear 600 vs 700. The 700 will give better mileage.
#70 | |
#71 |
^ I believe that's right for the 175/65-15 . The Prius C is the same as the Honda Fit base and Yaris as you stated . Not a big selection for variety . ^
#72 |
The RT43 T + H are a 1 ply sidewall . Not sure for the V .
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 07:58 PM |
| NEED USED TIRES!!! | natethegreat38 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 12-06-2008 01:11 AM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 02:23 AM |
