![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
New chirping sound
This seems to have started this morning. Rainy day, I was taking off from a stop light and spun the front tires a bit. Constant, high pitched chirping sound but it goes away when I push the clutch in. I sure hope it's nothing expensive, I've been out of a job since July. I have 32,800 mileage on my car.
Probably just the serpentine belt needing to be tensioned. Damp conditions can promote belt slippage.
If it's the serpentine belt, why would the sound go away when I push the clutch in?
Reducing load on the crank pulley.
Thanks, I hope that's all it is :)
For giggles also check around the water pump for leaks. More common than people think, but the water pump can easily go out around your mileage mark.
OK, I'll check for those leaks as soon as it stops raining.
![]() Drives: Toyota yaris 99 reg Join Date: Dec 2014
Hi everyone,
I am hoping to get some really good help from you as i have the aftermarket keyless entry system but not sure how to install it in my Yaris.Any help will be appreciated.Photo of the System kit is attached for reference. Thanks in advance |
#9 | |
And what exactly is this doing in a thread pertaining to a serpentine belt? Sent from my iPhone using Tapatalk
#10 | |
Sorry mate, I am not aware of what is oem. I am a new driver and like to do new things . Any help will be appreciated
![]() Drives: 2009 Yaris TS Join Date: Dec 2014
http://youtu.be/dBVrS-PBoxI
Now I'm not so sure it's the belt. Here's a video I made; it's making the sound but not as loud as it usually does. My camera didn't do such a good job with the noise. Sometimes it chirps, sometimes it chatters. Some days even though damp, makes no sound. Also, take a peek at the end of the video by that round rubber thing....is rust in that area common on those brackets? Is the water pump near there? |
Yes the wp is driven by the belt which is in close proximity to the rusty round rubber thing (RcubedT)
You apparently live in a state with heavy salt use in winter hence the rust. I wouldn't worry about it but have the front suspension bolt recall done or at least checked. I have to believe your noise is one of the accessories driven by the belt. Or at least, if it was my car I would remove the belt and see if the noise goes away and further spin and feel the rotation of the accessory pullys. Im thinking water pump.
#15 | |
yea, Bronsin is on it. It sounds like the throwout bearing as you discribed.
#17 | |
Is that throwout bearing part of the drivetrain warranty? I'd check myself but it's 4 degrees out and I'm staying inside. I was laid off from my job in July and TODAY I finally got a job offer! I start Monday and being on probation for 90 days I want to get my car in good condition but I hope I don't have to pay for the repair myself. That rusty bolt repair - I had that repaired about a year ago at Toyota right before the recall came out. PS: I don't ride my clutch, and I don't hold it in at stoplights. I learned a long time ago with my Honda CRX to put it in neutral at lights. |
Dont know if clutch is covered. Youll have to call the dealer. Good luck!
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 06:35 PM |
| chirping sound in the morning or after a long time parked | tyrone_yaris | DIY / Maintenance / Service | 7 | 04-20-2012 03:06 PM |
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-05-2011 12:56 AM |
| New Sound System - Sound Issues | click.mine | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 03-20-2009 04:11 AM |
| Chirping, squeeking sound | ToTo | Performance Modifications | 7 | 04-21-2007 05:29 AM |
