Old 02-09-2015, 10:30 AM   #1
volnix
Drives: 2007 Toyota Yaris
One Low-Beam Out
Hi,
My driver-side low-beam on my 2007 Yaris sedan went out this past Friday so I replaced the bulb over the weekend. Still no low-beam. I've checked the fuses for both bulbs and the main HLP fuse. I pulled the bulb out and verified that the coil is still intact (it's intact on my old bulb as well), so I'm inclined to think it's something else.
To add to the weirdness, I stuck the passenger-side fuse in the driver-side location to make SURE the fuse was good and got just a tiny little light, but certainly not the full illumination. This tells me the wiring is fine too.
I went ahead and replaced the fuse since I had some spares to no avail.
Also, both high-beams are fully functional still.
Anyone have any advice on what to check next? I'd love to fix this myself instead of taking it to the shop for a headlight out (just feels wrong lol).
Thanks!!
volnix is offline   Reply With Quote
Old 02-09-2015, 10:37 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I'd get two new fuses and replace both existing ones just to eliminate them out of the equation.
Old 02-09-2015, 11:09 AM   #3
volnix
Hey, sorry, I don't think my original post made sense about that. I already tried that since I had some spares laying around. Thanks for the help though!
Old 02-09-2015, 12:26 PM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Have you tried to swap the passenger bulb (known good bulb) and the drivers bulb (possible bad bulb) to see what results you get. While the bulbs are out. I would get a volt meter and check the voltage coming from both sockets and compare.
-Derrick-
Old 02-09-2015, 02:28 PM   #5
CoryM
Drives: 2009 5-door, 5-speed
Interesting. Unless your connector is melted (common with brighter aftermarket bulbs), I'd guess your "running light relay assembly" (aka DRL module) is kaput. Honda and Nissan et al are famous for this, but I haven't heard of a Yaris yet. I would suggest removing the module, pulling the cover off it and looking for a poor solder connection. Very common for other cars, and usually you can just re-solder it and are good to go.
Cheers.
Old 02-09-2015, 02:46 PM   #6
volnix
Cheers.
That was what I thought at first, but after a little more research determined it doesn't actually have a headlight relay. They're just straight-up headlights driven by the switch on the steering wheel stalk (not DRL or anything). Guess that's what you get when you have the basest base model they offer (it's a stick shift, manual windows, manual locks, etc.)
Old 02-09-2015, 02:47 PM   #7
volnix
I'm kind of surprised I didn't think to try this. That would at least give me a definitive answer to whether it's the bulb in any way. What voltage would I expect to see if things were functioning as expected? I'm pretty handy with most areas of car maintenance, but electrical is not one of them.
Old 02-09-2015, 07:19 PM   #8
If yours definitely does not have the H-LP relay, then try bypassing the headlight stalk (which is likely the culprit).
To bypass it for the low beams, on the headlight stalk connector jump the blue wire next to the pink to the large white/black wire.
Old 02-09-2015, 08:24 PM   #9
ex-x-fire
Get a test light & check for power & ground at the bulb connector. Test the fuses for voltage on both sides.
Old 02-10-2015, 09:51 AM   #10
volnix
From doing some more research yesterday, I'm thinking you're probably right. I'm out of town on business until tomorrow, but will try swapping bulbs and try bypassing the stalk tomorrow afternoon.
Thanks for everyone's help!
Old 02-17-2015, 09:14 AM   #11
volnix
FYI, I ended up getting bogged down with work and just couldn't find time to look at it so I took it to the shop instead. Embarrassingly, they said it was a bad bulb. Still don't understand how I managed to get a bad bulb from the shop, but oh well. Thanks for your help nonetheless
DIY Low intensity high beam ? JudgeM DIY / Maintenance / Service 1 12-08-2013 09:01 AM
DRL: Low beam or -lamps - or not? Ot_tO General Yaris / Vitz Discussion 10 07-27-2012 08:11 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 10:49 AM
Does anyone know how to rewire a Low beam HID kit, for both LOW/HIGH beam use? Syroyizhka General Yaris / Vitz Discussion 1 11-30-2009 11:47 PM
