Old 12-08-2013, 02:02 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Question DIY Low intensity high beam ?
Hello all.
I see that many of the American cars have daytime running lamps in the form of a low intensity high beam.
I would like day running lamps for my car however there is no conveniant place to attach those LED ones on my Vitz (I dont have slotted grills). Also I dont like the look of them. I would prefer keep a more stock look.
I have factory HID lamps so what they've done is made the low beam a HID bulb and the high beam a halogen bulb.
Is there anyway I can wire up the hi beam bulb to work at a low intensity, at the same time not affecting the operation of anything else?
I also saw there are these Toyota Day Running Light modules, would these work if I plugged it in to my car ?
Cheers.
JudgeM is offline   Reply With Quote
Old 12-08-2013, 08:01 AM   #2
Yaris/Vitz that don't have DRLs aren't wired for them, but it would be possible (with a bit of wiring) to install one of the OEM DRL modules to drive the halogen bulb. The US DRL module actually drives the low beam, not the high beam, but it does so with a pulsed output to decrease the intensity, so there is no reason why that pulsed output could not be connected to the high beam instead.
hid hi/low. question on using high beam for DRL! marcus Cosmetic Modifications (Exterior/Interior) 22 06-17-2010 03:12 PM
Package received from Taiwan! GabL Cosmetic Modifications (Exterior/Interior) 74 09-25-2007 09:37 AM
[HELP] Keeping fog lights when installing HID GabL DIY / Maintenance / Service 26 08-01-2007 10:27 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
