#19 | |
2ZR swap. DO IT! Ask how!
![]() (Shhhh, there's already one in my garage!) |
#20 |
Hmmmm.... Interesting! Are you holding out on us Sam? I found one on eBay for $40.00 - or maybe it was $80.00 - a year or so ago. I almost bought it when I was in the turbo system 'scratch build' thought process mode. Anyway, they are one solid, well constructed piece, aren't they. I only wish I'd sprung for the ceramic coated option when I ordered my kit. Mine started to get a wee bit of surface rust the few days after it was simply installed on the car.
#21 |
We've totally hijacked this poor person's thread! =D
I bought it as a pre-emptive measure so that I didn't miss out on it the way I missed out on the RPM long tube header. Zero plans to do FI on my daily driver, I can barely maintain it as NA. |
#22 |
You're right, we have hijacked. Largely my fault. My apologies to the op. Good to have the mani lying around, 'just in case'.
#23 |
![]() Drives: 09 yaris hb Join Date: May 2014
I'm still shopping around for the header. The MWR piece is a bit pricey for me though.
I did go ahead and buy all the stuff I'll need to build a complete 2.25 exhaust. Should be a pretty miserable job without a lift. My main job now is sourcing accessories and all the hardware that my engine is missing. |
#24 |
Does anyone have a good picture of the factory engine hooks?
I am going to weld up my own using some old ones I have of a miata. |
#25 |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
I've ordered some but they haven't arrived yet. Can take photos when they do.
#26 |
Here's the set I have on my spare 2ZR. Front is just a simple flat hook with an anti-rotation tab on the collar. Rear is a bit more complex because it is perpendicular to the mounting surface and has a slightly more complex anti-rotation tab.
#27 |
That is a great help. Thanks!
#28 |
Bought a WPN-R header on EBay last week for $280.
I can't imagine it will make much power over the stock piece but it is full stainless and well made. |
#29 |
That's a beautiful piece! It definitely looks like it would breathe better than the stock manifold.
#30 |
Discovered a large crack in my intake manifold this weekend...I'm having to source one from my local yard.
Does anybody have thoughts on which one is best? It looks like there are at least two designs and a recall on some of them. The placement of the vacuum hose for the brake booster is the only visual difference I can see. |
#31 | |
#32 | |
Its already gone unfortunately...I wish I would have seen this before they picked up trash yesterday. |
#33 | |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
https://www.toyotanation.com/threads...#post-14000058 |
#34 | |
#35 |
Haha. No worries.
#36 |
Was finally able to grab a passenger side mount from my local yard this weekend. This part has been the hardest one to find by far.
I'm also struggling to source a stainless exhaust flange in the factory size if anyone has any ideas. |
| Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 219 | 06-10-2025 03:58 PM |
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 05:59 AM |
| THE 2ZRFE engine swap thread - Just the facts | brushforhire | Performance Modifications | 40 | 12-25-2019 12:08 AM |
| 2zrfe Engine swap - $500 picked up | brushforhire | Items for Sale by private party | 0 | 03-17-2017 11:21 AM |
| My 2zrfe swap | brushforhire | Performance Modifications | 131 | 06-08-2016 10:43 PM |
