Old 04-06-2021, 03:05 AM   #1
stanhi
Drives: 2008 Yaris 2dr hatchback
Question Clutch pedal to 1st gear all the way to floor
I just purchased a used 2008 Yaris with 85,750 miles.
In order to get into 1st gear I have to press the clutch pedal all the way to the bottom of the floor. 2nd a little better, 4 and 5th only half way down. Is this normal or do I have a problem? Any way to avoid the 1st pressing to the bottom of the floor? Appreciate any advise.
stanhi is offline   Reply With Quote
Old 04-06-2021, 08:11 AM   #2
ex-x-fire
Check the fluid in the clutch master cylinder, maybe you have a leak.
Old 04-06-2021, 10:00 AM   #3
It may be possible you have air in the lines and need to bleed. If there is air, each time you press the clutch, the hydraulic pressure temporarily increases. What happens if you sit in car and just repeatedly press the clutch? Does it get stiffer?
Old 04-06-2021, 03:11 PM   #4
stanhi
Not fluid problem
Thanks for the suggestions. I just tested the clutch pedal response and it seem to be always the same. One problem I have is when starting the car I have to push the clutch pedal to what seems the floor and it does not seem to close the safety switch to turn on the engine. I have to press it several times and it finally catches. When I did the pedal test this morning it seems that I was able to get into 1st gear without pushing the pedal to far down. I suspect that since I have to push the pedal down so far when starting I may be pushing it to far down when shifting into 1 gear. Haven't tested it yet since I only drive twice a week.
Old 04-06-2021, 09:52 PM   #5
remcafee
youre supposed to fully engage clutch pedal anyways
Old 04-06-2021, 09:53 PM   #6
remcafee
how people here are not fully depressing their clutch pedals? am i just insane?!?!
Old 04-07-2021, 01:56 PM   #7
bronsin
bronsin's Avatar
Definitely. However it won’t take as much travel to change the higher gears.
I think your clutch system is fine.
However I recommend bleeding once a year
I don’t know how many posts I saw when I was riding my motorcycle that went like this quote I am in Alaska and my transmission won’t shift what’s wrong“
Your clutch Needs to be bled that’s what’s wrong!
Old 04-07-2021, 05:51 PM   #8
KALISPEL II
KALISPEL II's Avatar
Drives: '22 Mazda CX-30 CE AWD 6-AT
The Yaris had a pretty dismal manual driving experience (versus most other cars) prior to the 2015 refresh (which also improved the clutch design).
2015 Toyota Yaris SE Hatchback, Super-White, 5-Speed Manual (August 2015 to August 2019)
2020 Toyota Corolla SE Sedan, Super-White, 6-Speed Manual (August 2019 to February 2022)
2022 Mazda CX-30 AWD Carbon Edition (CE), 6 Speed Automatic (February 2022 to ???)
KALISPEL II is offline   Reply With Quote
Old 04-07-2021, 06:46 PM   #9
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
What did they change in the 15+ cars? I have a '14 and it has the infamous clutch chatter/shudder when its cool and/or damp out. Its infuriating.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 04-08-2021, 03:30 AM   #10
bronsin
bronsin's Avatar
It has to do with the throttle response of the drive by wire throttle. The old cable actuated throttles were much smoother, by the way 2001 Echo.
Old 04-08-2021, 04:38 PM   #11
KALISPEL II
I'm not exactly sure what was changed when they revised the Yaris clutch starting with the 2015 refresh, but my 2015 SE 5-MT was comparable to all the Honda 5-MT cars that I have driven over the years. No complaints or anything.
Old 05-23-2021, 03:59 PM   #12
stanhi
Sorry for the late update. A fried of mine looked at the situation and found the problem. The previous owner had put in a floor mat with a hump near the pedals. After he took away the mat there was no problem.
Old 05-23-2021, 04:02 PM   #13
bronsin
bronsin's Avatar
It’s great to solve problems!
clutch 1 gear, clutch pedal, clutch start
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 02:56 PM
New clutch, car is abysmal to drive tamrat DIY / Maintenance / Service 4 03-10-2020 05:39 PM
problem of gearing, 1st and 2nd gear, Yaris 2008, 1.3 VVTi 64 kw cylaptor DIY / Maintenance / Service 18 03-05-2019 11:40 AM
Car/engine shake when releasing the clutch pedal hystria DIY / Maintenance / Service 16 07-22-2007 08:56 PM
Hard clutch pedal ? hystria General Yaris / Vitz Discussion 5 05-11-2007 07:12 AM
