Old 12-02-2025, 02:08 PM   #1
selwynk
Drives: Yaris2009
Oil Filter YZZN2 not tight enough
Hi
Last weekend I replaced my oil filter on my 2019 Yaris which is the black oil filter 90915-YZZN2. The instructions on the oil filter states..... "Tighten the filter another 3/4 turn with the dedicated tool after the gasket makes contact with the installation surface"
I marked out the 3/4 turn, almost certain I tightened 3/4 of a turn using a proper oil filter tool so I am bit puzzled as to where I went wrong.
When I replaced the oil filter I took the car for a drive (+/- 30km) making sure there are no leaks but this evening I noticed a thin layer of oil around the oil filter so it appears there is a small leak, no drops forming on the oil filter so the leak appears to be small.
My questions are:
1. Can you tighten a filter which is already in use or you recommend a new oil filter?
2. Could I tighten more than 3/4 turn without doing damage? Would one full turn be the maximum?
3. Both the 2009 and 2019 Yaris use the same oil filter what is the torque spec?
Thanks in Advance
selwynk is offline   Reply With Quote
Old 12-02-2025, 04:00 PM   #2
I always tighten a filter until snug, then give an additional 1/4 turn. Snug is well past the point of gasket making contact.
Old 01-05-2026, 08:11 PM   #3
alanwagen
Originally Posted by selwynk View Post
Hi
My questions are:
Thanks in Advance
It could also be residual left on your engine from the oil change. Check the tightness and wipe everything off.
1nz-fe larger oil filter Compeer DIY / Maintenance / Service 8 12-15-2022 04:22 PM
Any benefit to changing just the oil filter? bairjo DIY / Maintenance / Service 17 10-05-2014 07:21 AM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Longer Life Oil Filter? Yar Is Word DIY / Maintenance / Service 14 07-19-2010 06:35 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
