I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
toyota
oh!
I want JDM bumpers!
#4 | |
toyota
http://www.yarisworld.com/forums/showthread.php?t=7520 by the way recent fix on this update 06/25/2010 just disconnect blue wire fr relay. Last edited by marcus; 06-24-2010 at 03:37 PM. |
all new toyota's are actually ground switched. so you basically can get a constant + (red/positive) anywhere in the car.
![]() ![]() ![]() Drives: 2005 Toyota MR2 Join Date: May 2006
For a normal bi-xenon retrofit, we want to use this diagram (created by JAZZ, posted @ hidplanet.com):
![]() #1, #2, and #3 refer to pins on the female socket (plug) for the stock bulb. True bi-xenon headlamps use a single HID bulb that provides light for both low AND high beam. The projectors in these headlights have a cutoff shield that can be moved up/aside by a solenoid (same way old fashioned doorbells work) to allow more light to escape, forming the high beam. To mimic the bi-xenon feature, GabL's kit uses an additional bulb to provide the high beam (there is no projector/shield/solenoid/etc in a regular Yaris headlight). While technically, I could erase "Bi-Xenon Solenoid" on the diagram and replace it with "High Beam Bulb," I think we can simplify things even further. You'll notice that in the above diagram, relays are used for both high and low beams. I think we can skip the high beam relay because GabL's kit uses a regular halogen bulb, which is exactly what the stock wiring is designed for. I am now modifying the diagram to fit GabL's needs in part4/post4. --------------------------------------------------------------------- Real quick before I start part 4 / post 4: Guys, keep in mind I don't have a Yaris (my girlfriend does)... If anything here doesn't make sense or doesn't match up with your car, let me know. Also, use your common sense. If anything feels dangerous or uncomfortable, stop and think it through before risking hurting/killing yourself. Your bulb plug looks like this, right? ![]() If so, then you probably want to order a MALE connector from here: http://www.comagination.com/parts.htm You could cut your stock wire, but... I think that'd be a REALLY bad idea. People doing single-xenon (low beam only) or proper bixenon retrofits will only need 1. If you have a kit with HID low and halogen high like GabL, you will need 2 (one pair), because you are going to use the high beam wires from both sides to power the high beam in your kit. I recommend buying the connectors without wires, because I recommend using thicker wires. I used 12 gauge wire for my setup, but I have a mid-engine car so I had to run wires all the way from the back of my car to the front. People say 14ga is plenty good, and 16ga is fine too. In my opinion, 18ga is the thinnest I would go. If you want to, you can use their connectors with 18ga wire since it will be easier to use. Your choice. Also... I bought 6 connectors (without wires) because I knew I would screw up and need replacement spades (the pins that go into the stock female plug). I ended up using most of them. I suggest you do like me and buy extras, otherwise if you screw up you'll have to wait for a few days while they ship you new ones. If you buy the connectors with wires, a screwup is easier to fix - you can cut off part of the wire and try again. Still, if you're doing a $200+ HID retro on your $15000+ car, then you may as well spring the extra $5-$10 for a few extra connectors, just in case. |
Notice that in the diagram in my last post, there's only one set of H4 (common/high/low) wires. This is okay in that case because the stock wires are only used to trigger relays, which takes almost 0 power.
For GabL, I want to eliminate the high beam relay. ...To be continued (working on diagram) |
I want JDM bumpers!
Hey GuySmily, thanks for the info!! However, I am not getting a HID kit, but rather I'm having an OEM module (see my other post http://www.yarisworld.com/forums/sho....php?p=119097). And it seems that I can keep the factory setup and just re-route the wires to match the lights, but the problem now is the find the matching connectors to fit onto the ones on the headlight module... I hope I don't have to fly to Taiwan to get them...
Wow, I didn't realize it was an entire housing and everything. I'm both impressed and appalled that Toyota did this (usually halogen+xenon sharing same bulb is considered to be cheap aftermarket garbage)..
Anyway... In that case, I'll stop where I'm at with this post and continue the discussion in your original thread. For anyone who is wiring up an aftermarket semi bi-xenon (hid low, halogen high) kit, here is the wiring diagram you'll want: ![]() Let me know if you need further help (or see GabL's other thread) |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 3 | 10-20-2008 05:36 AM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 4 | 09-26-2006 10:48 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
