![]() ![]() Drives: Racin' yaris :D Join Date: Nov 2012
Hey guys, What is the difference between 4-2-1 and 4-1, in performance I mean
0-60 in slow
Depends on how they are designed, but if both are designed correctly there should be almost no difference.
#3 | |
play every day
A 4-2-1 tri Y header pairs up sequentially firing cylinders 2-1 and 3-4 so that the exhaust pulse from one helps to draw exhaust from the other. ![]() ![]() Then the combined 2-1 and 3-4 pairs join to help scavange each other... ![]() Practically speaking, the headers are too short to make a lot of difference. But that's where namer comes in...
Form>Function
The 4-1 is supposed to delay the power increase until higher in the powerband. The 4-2-1 is supposed to give a midrange bump. On our tiny cars you probably would never notice a difference. I love my DC header. Anytime I'm above 4k I'm just roaring and pulling hard for a yaris lol.
play every day
I actually did notice a difference...
...as I climb a steep 1/4 mile hill in 2nd gear to get to my house. It's always the same hill, so that's constant. And driving up it everyday I have a good feeling for the resistance. The header definitely helped the engine make it up the hill easier. If you start climbing under 2,000 rpm, the engine labors sluggishly. But anything over 2,000 and it gains rpms much easier and climbs more easily than the stock header which feels like it's holding back at the same rpms. |
^ An aftermarket header will certainly make a difference over stock, but I doubt you can feel any difference BETWEEN aftermarket headers. You just can't feel 1-2 horsepower, in my opinion.
#7 | |
Form>Function
Tr that pic I think is sporting a MI Hood visor. |
TRYaris is that your car in your avatar?
0-60 in slow
Basically what Cali said.
There is a maximum of about 12" to work with and an ideal length of about 35" so most of the ots headers compensate by increasing the volume of tube which in essence give some of the same effect as increasing length but reduces scavenging at lower rpms. Now this motor is relatively small displacement with a good torque management system going to a larger diameter tube won't hurt you as bad as it would on a larger engine. So not wanting to give up anywhere in the powerband while still gaining some up top is the reason I decided to design and build my own header. As far as header type is concerned both a 4-2-1 and a 4-1 will accomplish the same goal but each design has its own advantages but both of them can produce near the same power and torque so there isn't a real advantage to choosing either one aside from packaging constraints, and a 4-1 is simply easier to package with the effecting lengths required. |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
This is what I received yesterday
http://photo.qip.ru/users/tolmach/96608749/129617602/ Same part number but Dc logo seems to be on the fourth tube as compared to this one (stole this pic from someone here) - here logo is on the third tube http://photo.qip.ru/users/tolmach/96608749/129617601/ have not tried installing it yet, but there seems to be enough space between the hole for the O2 sensor and top bracket Overall build quality of mine is not very impressive (kinda very average) as compared to the WR one |
play every day
That's one thing I really like about the Weapon R. It's precise. You could cut your finger on that sharp knife edge where the two main tubes are joined...
![]() But as far as performance, it doesn't matter.
0-60 in slow
That's not a good thing, air doesn't like sharp edges.
#14 | |
Mine looks nothing like this inside (build quality wise) (( Hopefully, will still do its job |
0-60 in slow
I wouldn't worry, all of the aftermarket headers lack a ventur,i so the collector looking bad wol make almost no difference.
#16 | |
play every day
The DC is a time tested design. And in my opinion, trailing edges don't matter. Those are the edges that point in the direction of the exhaust flow. |
I don't think it would make that much of a difference in our case either way.
![]() Any aftermarket header should prove to be at least slightly better than stock, right?
