Old 12-02-2008, 08:43 PM   #11
Originally Posted by ivanmadeline View Post
I tried doin it on Sunday but the problem I had was that when I hit the button the light would start flashing the it would come on then I hit the button again and the same thing it would just flash for a few minutes and then stay on again.
I dont know if this makes a difference but i Dont have a brown cable on mine I have a white with a black stripe were that brown one is on your write up. Any suggetions. thanks for all your help.
Can you take a picture of your connector? The part number is the same for 08 and 09 sedans and LBs, so even though the wire colors are different, their functions are identical.
If your connections are in the correct place, try measuring the voltage on the "brown" wire with the switch in both modes. With the TPWS connected (and the sensors not present) you will read ~1 VDC. Withe the TPWS bypassed you should read ~4 VDC. If the voltage is less than 3 VDC, the light will remain on.
If you do measure less than 3 VDC, you will need to change the resistiors to 150 ohm, 1/2 watt ones.
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
