Old 02-13-2009, 05:54 PM   #1
Split
Drives: 2008 Yaris Sedan
i dunno.. i guess 195 would be okay. Just 195 seems so small ?
Split is offline   Reply With Quote
Old 02-14-2009, 12:27 PM   #2
Benggolf2
Benggolf2's Avatar
Am running on 17x7 +40 wheels with 205/40R-17 tires. Car is lowered with Eibach Pro-Kit springs. Also installed a 10mm H&R spacer on the rear wheels. Absolutely no rubbing issues.
You shouldn't have any rubbing issues with 195/50x16 tires on +43 offset;otherwise get the +45 offset if you want to run on 205s to be on the safe side.
Benggolf2
Old 02-13-2009, 06:13 PM   #3
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
FYI, I believe stock offset is +45 (at least on the 15" steel wheels).
For everyday driving, you'd probably be hard pressed to notice the difference between a 195 and 205 tire. If you're concerned about the rubbing, go with the 195.
Old 02-13-2009, 06:35 PM   #4
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
I myself am running 17x7 42mm wheels with 205/40 tires with no rubbing when I've bottomed out or doing full u-turns. I've read a lot of post here with users claiming to have no rubbing with 42mm offset wheels. Even people running bigger tire sizes then the one you're considering. Some post mention rubbing, but most of them dont have issues from what I've read.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 02-13-2009, 06:47 PM   #5
Split
^ i just dont know what to believe anymore =/
Old 02-13-2009, 09:01 PM   #6
The tread on an A048 195 tire puts more rubber to the ground than my BF Goodrich 205's in the same height series. Look at the shape of the sidewall -- definitely differences to be found between brands.
Old 02-16-2009, 01:56 PM   #7
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
although if comparing similar types of tires you can have a good gauge.
A048s vs R888s would be a good comparison.
RE760Sports vs BFG KDW2s
etc.
looking into measured section and tread width on a given wheel width tells a lot more then the sidewall #s.
a little article on the topic.
http://t3hclap.com/archives/43
just to show the differences. And no you can't run that size tire on a yaris.
Russelt3hPirate is offline   Reply With Quote
Old 02-13-2009, 09:09 PM   #8
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
besides the 15's i also rub with my 215/35/18's. its not an issue with me cause i chose to live with it but i hear it on harsh bumps and when i cut wheel too hard left or right.....
Old 02-14-2009, 09:53 AM   #9
kimona
kimona's Avatar
Drives: 2014 White VITZ
The fact is that 205mm tyres, for example, actually differ in width by brand and model; all 205mm tyres are not created equal.
Wheel offsets are not always entirely accurate, as well.
Plus, the car itself is built within acceptable design tolerances, so not only does each car differ, but the same car can differ from right side to left side.
EDIT: These variables along with the fact that the Yaris is already pretty tight when it comes to proper wheel/tyre fitment... and you've got a rather fussy little car.
Old 02-14-2009, 10:09 AM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
i think it's just the fussy little owners ;)
Old 02-14-2009, 12:30 PM   #11
SailDesign
Drives: .
Pot - meet Kettle...
Old 02-14-2009, 12:38 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
how am i fussy.. i run many different offsets /wheels/tires and don't throw a fit if i get a little rub once in awhile ;)
Old 02-17-2009, 02:11 PM   #13
eii
Rides canyon walls
eii's Avatar
I noticed this when compairing my falken ziex 912s to other pictures of tires that were the same size. My 912s are not as wide and I suppose that helps prevent rubbing.
Old 02-14-2009, 12:34 PM   #14
^ ha, beat me to it!
Old 02-28-2009, 07:39 PM   #15
Split
looks like we'll be running rota circuit-10's, 16x7, +et45mm. I really want 205 width tires, because any narrower just looks so narrow! Looks like BBS has some good high offset wheels, but they're so damn expensive. I have some 18x7.5 BBS wheels on my IS300, and they're +50mm offset. Definitely not rubbing with those! I wish they were wider though. I could have easily fit a 8" in the front, and a 9" in the back with that offset. I'm running 225 front and back, but i could have done 235front, 245rear =/
What are you doing right now? Bob_VT Off-topic / Other Cars / Everything else Discussions 26819 12-31-2010 10:48 AM
want 2 lower with tein but have tyre rub HELP! MR. CANTON Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-24-2007 04:16 PM
Got new wheels, tires, and springs installed. largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 44 09-22-2007 04:21 AM
SSR Integrals 16x7 +42 santosspl Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 07-24-2007 07:12 AM
