03-16-2009, 09:09 PM
#36
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra
Originally Posted by kurokoma-kun
Crap, I have got to get off my a$$ and install my gauges! Without knowing the AFR, seems like knowing the ignition timing means nothing
Currently I just gave a tach and scangauage on volt, ign, tps, and cycle through others (load, loop, temps). I have boost/vac and wideband a/f and oil press. still in their boxes
Cruising around at 2500-3500 rpm, the tps is ~25, load is say 50, ign timing is usually ~30. Under boost (load 99 and tps 25+) it quickly drops to half that... is that normal?
Yes that sounds correct.
