Old 06-02-2009, 07:55 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Thanks for the update we are all eagerly waiting. I got my custom hub spacers now i need a throttle body spacer.
Old 06-02-2009, 08:30 PM   #2
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
don't worry, pieces to the CNC are already coming in the mail everyday, today i got the computer unit and the motors, yesterday i got the DRO unit, it should be getting drop shipped soon!!!
Old 06-02-2009, 09:09 PM   #3
JBIZZ
Drives: 2007 Liftback white
I'd be interested in one, as long as, my warmup idle doesn't raise anymore than 3K rpm.
JBIZZ is offline   Reply With Quote
Old 06-02-2009, 10:29 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
this is a spacer, not the throttle body swap
Old 06-02-2009, 09:10 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i didn't read the whole thread but i didn't see this mentioned in the first few posts.
what material are you making this from?
Originally Posted by xnamerxx
you nailed it sir.
Old 06-03-2009, 01:10 AM   #6
Nexus1155
Drives: Audi
Aluminium.... why? lol
Old 06-03-2009, 01:31 AM   #7
Tamago
Tamago's Avatar
Drives: ZZW30
if you want optimum performance, make it from phenolic
you nailed it sir.
Old 06-03-2009, 01:29 AM   #8
^ I like the English spelling version. My vendor in India spells it that way.
Old 06-03-2009, 01:46 AM   #9
Phenolic resin can include any of various synthetic thermosetting resins such as Bakelite, obtained by the reaction of phenols with simple aldehydes such as formaldehyde. Phenolics can be used to make molded products including pool balls, laboratory countertops,[1] and as coatings and adhesives.
Phenolic material properties are useful in myriad industrial applications. Phenolic laminates are made by impregnating one or more layers of a base material such as paper, fiberglass or cotton with phenolic resin and laminating the resin-saturated base material under heat and pressure. The resin fully polymerizes (cures) during this process. The base material choice depends on the intended application of the finished product. Paper phenolics are used in manufacturing electrical components such as punch-through boards and household laminates. Glass phenolics are particularly well suited for use in the high speed bearing market. Phenolic micro-balloons are used for density control.
http://www.sdplastics.com/phenolic.html
Old 06-03-2009, 03:01 AM   #10
dallas
Drives: Yaris Hatch /Landrover D2
O.K Spock LOL.
dallas is offline   Reply With Quote
Old 06-03-2009, 07:41 AM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
so, garm, you can cut and paste!
but why would i suggest using a phenolic plastic over aluminum? anyone?
you nailed it sir.
Old 06-03-2009, 10:10 AM   #12
Nexus1155
Drives: Audi
phenolic spacer to keep IAT down because it doesn't conduct heat. It might be a more suitable idea than using aluminum as it may be cheaper and we can keep costs down for this econobox. But what about if theres constant abuse of spraying, does this material take well to something like that?
Old 06-03-2009, 11:22 AM   #13
Tamago
Tamago's Avatar
Drives: ZZW30
it should hold up BETTER than aluminum, as aluminum tends to rot when exposed to nitrous oxide.
you nailed it sir.
Old 06-03-2009, 11:29 AM   #14
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Alum will get hot from heat soak. Nitrous is very cold when it is being released. So if you have a hot piece of alum. Say 115 degrees F (the hottest I have seen my IAT) the alum could crack from the rapid change in temp. Is that what you were going for tamago?
Old 06-03-2009, 11:52 PM   #15
Nexus1155
Drives: Audi
LOL thanks Garm i love that spelling too.... Yeah, if thats the case, why do they make the Hemi ones which takes a bigger jetting than a yaris would handle in stock form in aluminium. I dunno, all nitrous spacers are made from aluminium, i don't think theyd do it all willy nilly, if you want me to make it from phenolic, i don't care, its just general concencus
Old 06-04-2009, 02:09 AM   #16
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I don't think heat soak will be too much of an issue considering the TB is metal as well.
Old 06-05-2009, 05:40 PM   #17
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I think plastics would be a better material for these spacers, based on what I've heard... Cheaper, more resistant to temp fluctuations, and you can fabricate them using the same process.
Old 06-05-2009, 07:52 PM   #18
The correct length studs and bolt should be included with the spacer, and I'm sure they would do it that way so we don't have to source our own parts.
1ZZ Throttle Body Spacer tk-421 Performance Modifications 34 07-11-2017 10:48 PM
Spacer Template for Hatchback Aftermarket Speaker Install bigsky2 In Car Entertainment + Electronics (audio / video / alarm) 19 03-12-2014 02:53 PM
Ideal Spacer Width For the Rear? tk-421 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 01-27-2009 06:59 PM
DIY Spacer Templates for Speakers - Hatchback bigsky2 DIY / Maintenance / Service 9 09-22-2007 07:16 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-02-2007 12:38 AM
