Old 04-22-2009, 10:17 AM   #1
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
Originally Posted by CtrlAltDefeat View Post
actually... it would be like running 2 turbo 750cc motorcycle engines attached at the crank and as far as the separate turbos for half the engine, I believe they have been doing that with v8s and v10s for a while now...
no they haven't, generally they share a common intake manifold for all the cylinders.
they may have two throttle bodies but the Intake Manifolds are connected (in the event they have one per bank (intake manifolds/throttle bodies).
how would it be like two 750cc motorcycle engines? i'd love to hear your reasoning for that example.
Russelt3hPirate is offline   Reply With Quote
Old 04-22-2009, 01:22 PM   #2
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
because its a 1.5l engine which equals 1500cc which equals 750cc on each set of 2 cylinders, or 2 sets of 2 cylinders at 750cc each...
Old 04-22-2009, 01:31 PM   #3
Russelt3hPirate
l33t3st Asshole
give me an example where you've seen 2 turbo 750cc motorcycle motors attached at the crank running multiple throttle bodies and no sharing of their intake manifolds.
you're not going to win this argument b/c it's pointless.
a twin turbo setup with 1 intake manifold is surely possible but there is no point to run one turbo off two cylinders into 2 cylinders, then have another turbo running off the other two going into the other two...... :lol:
how did you plan on intercooling this setup?
wait, let me guess, dual intercoolers too?
are you going to run two fuel pumps too?
one for each "motorcycle engine"?
come on now.
do a twin turbo setup, run one turbo off two and the other off the other two, then go into 1 intercooler, then into ONE INTAKE MANIFOLD.
look at that, you've got an over weight turbo setup that makes less power and is less drivable then a properly chosen setup single turbo.
if you're looking for better spool invest in a twin scroll turbo that is properly sized for the engine.
save you a few clicks, http://tinyurl.com/corza8
thoughts?
open for discussion.
Old 04-22-2009, 01:49 PM   #4
CtrlAltDefeat
I ♥ Yaris
come on now.
thoughts?
Well its not an argument, it was an interesting off the top of my head theory. I appreciate your input but not you attitude. And if you scroll up a bit you'll see I mentioned dropping the dual intake... This all started when I thought about the possibility of using 2 small turbos for less lag then 1 big turbo... Of course I'm a noob to forced induction modification, I mentioned it at the beginning. It's pretty much all hypothetical, so yes i thought about using dual motorcycle intercoolers, and dual exhaust too (about the same size as stock piping so all the low end power wouldn't be lost)
So thanks for your opinion, but in the future keep in mind the spirit of the thread, and keep the trolling to yourself.
kthxbai
Old 04-22-2009, 01:54 PM   #5
Russelt3hPirate
l33t3st Asshole
kthxbai
will do.
in the spirit of the thread.
2 turbos, 2 full exhausts, 2 intercoolers.
if you like car shows then you'll get points, if you like performance you'd might as well do the following
1 turbo, 1 full exhaust, 1 intercooler
and be golden. :D
Old 04-24-2009, 01:49 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
. If this makes no sense what so ever, please let me know, and why.
kthxbai
i can do nothing but LMFAO at this.
where are you going to put your throttle bodies and mass airflow sensors?
but more importantly, where are you going to put two turbos in a yaris engine bay?
Old 04-24-2009, 03:08 PM   #7
Russelt3hPirate
l33t3st Asshole
that's not the point, this conversation is built on hopes and dreams not reality.
A properly setup single turbo system in a yaris will out perform a twin turbo yaris any day simply b/c the single turbo will have more time on the road with more tuning. the twin turbo is still in the shop trying to figure out how to run the intercooler piping while still keeping the stock battery, b/c the customer wants to keep his cool battery tie down.
Turbo from Starlet on Yaris? Adamantite Performance Modifications 15 09-22-2006 05:42 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
