![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2009
High Flow Catalytic Converter
Has anyone installed one? If so, what kind and did it improve any performance, like mpg :D ?
I want to install the set-up like Marcus with his magnaflow... they sound nice and its not too loud... I like to have a nice smooth exhuast... :D |
i have one. it's a magnaflow 2.25" hi flow cat. 12" long. used it to quiet down my header back exhaust, and it did. however, i only have the hiflow cat and a 18" resonator. can't help ya with any info for the mpg department.
http://www.jegs.com/i/Magnaflow/642/54305/10002/-1 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
you should look into random tech cat's. it's a pipe...that catalyzes the exhaust. its just like a straight pipe, only emissions legal.
![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
I thought changing the cat converter was illegal. Is there any way to do it legally or does it even matter?
#5 | |
it's illegal to remove a cat from your vehicle, but if you replace it with another cat you may be in the clear. if your state does not do emissions testing then you're definitely in the clear. i'm running a magnaflow spun cat as well.
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
In Hawaii, Not having a cat is Illegal. Replacing it is not. WE don't have Emission testing though...
Most Satisfying Crew Serious Business... MunkyWurks Garage - 8088488794 |
What are the benefits of changing the cats - more horsepower?
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
I dont have any dyno numbers but when I installed my nitto mid-pipe with "cat delete" I could feel a slight differnce , mabey good for 1-3 real hp's .
Garm is permanently high because he is the king of smokin' deals! |
37HSSV
High flow Cat > OEM Cat
main thing is being able to be legal when it comes to state testing...and doing your part in being more green. If you want more horses, go straight pipe to muffler. BUT you will no longer pass any state inspections or testing, and you can get popped my local law enforcement if they check to see if you have done a cat delete.
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
High flow cat isnt really even a cat its just a strait pipe that has catalist around the inside it maybe has 5-10 percent of catalist that a normal cat would have. Also is not smog legal anywhere.
wanna bet??? i had better emissions on my camaro with the random tech than oem.
#12 | |
Sorry but putting something in that has lower catalist efficiency and less catalist will not magically make the emissions out of the tail pipe cleaner. Its called the law of common sense. Now if its on a car that has already extremely clean emsisions and you delete the cat you may not see much change in emissions but definately wont see a improvement. |
No one said if they had or even noticed any power increase. Or even if it maybe just helped the engine rev up a little quicker.
Well, Maine has no smog testing or emissions test at all, so that would be sweet for custom
you guys are also installing 2.25" pipes on these cars? But isn't 2.25" a little too big? Whats the stock diameter of the exhaust pipes?
Back in USA in days!
1.75"
Kazera KZ-V Silver Rims, with 215-35-18 Kumho ESCTA ASX, TRD Springs, TRD Sway Bar, Fujita CAI, Blitz R-Vit i-Color, Blitz Throttle Controller, Megan Header, 2.25 Stainless Cat back Exhuast, 50 Series Flowmaster muffler, 6000k HID. |
I am running 2.25" from the header back; but i have the blitz s/c kit.
| TRD High Flow Oil Filters | Jansen | DIY / Maintenance / Service | 20 | 05-25-2009 04:36 PM |
| The Advantages of Nitrous on an Engine | KCALB SIRAY | Performance Modifications | 7 | 01-02-2009 10:53 AM |
| New CAT Converter story.... | jlift | DIY / Maintenance / Service | 14 | 06-03-2007 01:23 AM |
| High-to-low converter | Kaotic Lazagna | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 05-21-2007 01:18 PM |
| catalytic converter question | SamDaYarisMan | Performance Modifications | 14 | 09-08-2006 10:18 AM |
