![]() Drives: Yaris Join Date: Nov 2008
Hello Everyone. First off I want to say that this seems like a very helpful community from what I have browsed so far. Hopefully I can aid in being helpful as well.
I am the owner of Fluid Motorsports.com (.net is someone else) and I mostly cater to the MR2/VW/RX8/Subaru community. I am using my partners SN since its easier this way. I am currently in the process of making front underbody diffuser panels for the MR2 Spyder. However in order for me to buy enough plastic sheets to get the cost at a highly desirable pricepoint, I need to make at least 20 panels. I figured I would try out this forum as well since the Fits are already known for good mpg. To give you an idea of what I am reffering to please see this this link and pic: http://autospeed.com/cms/A_2456/article.html ![]() The rear diffuser smooths out the air from underneath and provides a smoother exit. As a bonus it also help to add downforce since the air underneath the car is moving at a much more rapid rate than the air on top. A lower car will get better mpg as its having to fight less air. I myself have a metal skidplate (which doubles as a diffuser as well) in my 250hp AWD Golf R32 and I can now see 30+mpg on the highway on a daily basis. Keep in mind this car is heavy and shaped like a brick. 33mpg was attained in below 32 degree weather! (cold weather is not good for seeing high mpg figures) ![]() ![]() So as you can see an underbody diffuser would help greatly. We already have a 2 door Yaris to work on so I can start making measurments. Due to shipping, the panels would come in two halves with a bent joint on each end to make attachment a cake job. Before possibly becoming a vendor on this forum, I would like to know if there is interest for this. I dont necessarily need 20 people here but on both forums I need a total of 20 people. Price is not set but would be somewhere between 120-140 shipped. All neccesary hardware would be included. I havent decided if 3m tape will do or if screws will be necessary. If I can get enough interest I will order a batch of sheets and begin making panels to provide pictures. Please let me know what you guys think.
sales@fluidmotorsports.com |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Honestly, I'd be interested in this, but only if the end product looks similar in fit/finish to the unit in the link you provided.
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
I love momentum.
I'd be interested if the plate had an access door for the oil drain plug and filter. I don't want to have to pull the panel everytime I do an oil change.
Thanks! |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
i understand the smoother air flow but how does more downforce = better mileage?
the way I understood it the more downforce the slower the car. the slower the car the more HP is needed to maintain the same speed.
The early bird gets the worm, but the second mouse gets the cheese. |
![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
This actually reduced the front-end downforce to an extent, because there's less for the air to 'catch' on the front-end underside of the car. It just slips past much more smoothly, the improvement is dramatically less turbulence.
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
with that said, the panels sound like an interesting idea ;D
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
While I appreciate the focus on fuel efficiency this is like just about every other FE mod in that the MPG gains are so small as to be unquantifiable, especially since it only covers a small part of the under body and the Yaris (at least the LB) already has belly pans in the nose.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
woops. I had made this post on the Honda Fit forums originally since I plan on making one for them as well. Just change the word Fit to Yaris :P
#10 | |
I'm interested. How is it different from this underpanel? http://www.yarisworld.com/forums/showthread.php?t=17894
this increase engine temp, because of hot air flow reduction.
i do not like it. |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| 52.60 mpg | Kaotic Lazagna | Fuel Economy Forum | 42 | 05-19-2009 01:45 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
| Toyota Yaris MPG Review at www.mpgomatic.com | aca72 | Fuel Economy Forum | 23 | 10-31-2008 03:59 PM |
