I just installed my set, but the passenger side is rubbing (I guess I should've made sure I got 2 10mm sets before installation). Also, one of the screws on the driver side (lower-right) did not go through the hole, so I ended up using a shorter one instead. Is that OK?
#3 | |
i'm trying to recall if i sent lock washers with your set or not. a lock washer should space the bolt out so it doesn't touch the axle. are you saying i sent you a 10 and a 13? please double check this, as my counts are still even in my inventory
#4 | |||
The lower-right bolt on my passenger-side rear wheel went in fine, but it didn't go out, meaning that the hole at the other end wasn't large enough to fit the bolt. I ended up using an OEM bolt instead, which didn't go through by 3-4 threads, so I'm a bit worried it may snap. Quote:
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
| Gauging interest on hub spacers for the yaris | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 61 | 05-22-2009 02:18 PM |
| Rear Spacers... (Who sells them?) | Saggio | General Yaris / Vitz Discussion | 6 | 02-06-2009 08:40 AM |
| Installing a rear window defroster | trn9 | DIY / Maintenance / Service | 0 | 01-06-2009 02:56 AM |
