Old 06-11-2009, 07:13 PM   #1
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
My suspension setup: Breakfast Blend for the angry panda
for those of you following This thread here on yarisworld, i've spoken a bit about my new suspension setup.
i know this is not a yaris, but the basics will apply and hopefully inspire some of you to "try this at home" (or maybe convince me to build some custom coilover sleeve kits for the yaris front end? )
thanks to kngrsll for the killer deal on the Koni Yellows! if it wasn't for you i wouldn't be even doing this project right now!
my suspension setup will be the following
Koni Yellows (Sport) adjustable shocks/struts
Ksport rear perches and springs (the plan is to upgrade the rear spring for something stiffer)
AFCO front coilover sleeves and 400lb 7" race springs
Things i know i'll have to modify:
The koni yellows have an upper spanner that is about 2.120" in diameter. this poses a problem as the sleeve kit is a 2" diameter. i will be turning the strut body tonight in the lathe to accomodate the sleeve ID
The AFCO upper spring mount hole diameter is about .10" larger than desired, so will have to be either welded in/machined out or i'll build a bushing sleeve to keep them from rattling
The Ksport rear springs are a puny 2.2KG/mm rate. Ksport swore up and down that they couldn't sell me any other rate than 2.2kg/mm so i guess i'll have to live with it for now. I will also address the problem that other companies have had by installing limiting straps or cables to keep the rear suspension from extending fully unless manually released. this will keep the rear springs from popping out if the car were to go airborne.
That's it for now! i think i'll cut the strut bodies down tonight before leaving the shop, so i'll snap a couple shots of that process
~joel
Originally Posted by xnamerxx
you nailed it sir.
the angry panda gets angrier... Tamago Off-topic / Other Cars / Everything else Discussions 11 12-09-2008 01:43 AM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 03:05 PM
