Old 06-12-2009, 10:46 AM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I've not laid hands on an xA, but don't they have about the same hood/windshield/top shock mount geometry? Doesn't look like the upper strut mount clearance under the hood would be much different.
Old 06-12-2009, 10:49 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
well, let's put it this way. i can remove my struts easily without taking off the wiper tray :) we have a 3-bolt upper mount as well, which aids in camber plate useability.
how would you get a camber plate to work on your single-bolt setup anyway? :curious:
Old 06-12-2009, 11:10 AM   #3
Loren
What?
Loren's Avatar
Damned if I know! There are bolt holes they use for the strut tower brace that might be usable. Or do a completely custom weld-in camber plate, or drill some holes to bolt to.
Never really thought about it because it just doesn't seem feasible due to space constraints, and I don't feel that I need it, anyway.
Old 06-12-2009, 11:41 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
you really don't. a slotte strut or camber bolt is just fine, but i like the idea of being able to run -3degrees up front on race day and dial it back for tire life wihout having to hit the alignment rack every time. can't really do that very well with camber bolts IMO
Old 06-12-2009, 12:58 PM   #5
kngrsll
Apexing Egg!!
kngrsll's Avatar
this is what i would do. i thought about trying the general application Ground Control mounts before, but i am with Loren, we don't really need travel and we can get camber below. It would be nice to have some caster, but we could also do that with an offset LCA bushing in the rear most portion like the subaru anti-lift kits.
http://www.ground-control-store.com/...p/II=136/CA=97
http://www.perrinperformance.com/pro...ory=8&model=26
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 06-12-2009, 11:18 PM   #6
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Impressive work
the angry panda gets angrier... Tamago Off-topic / Other Cars / Everything else Discussions 11 12-09-2008 12:43 AM
Suspension Setup Question Ran Kizama Wheels, Tires and Suspension Forum sponsored by The Tire Rack 27 04-28-2007 02:05 PM
