Old 06-24-2009, 08:06 AM   #1
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I don't think my daughter's '01 with AT did. (At least in "Drive.") But you'll be able to feel it if it does. It's really pretty subtle, not a great lurch. You have to pay attention to it.
Old 06-24-2009, 12:26 PM   #2
kenora
Drives: 2009 Yaris LE 5 dr
Mine definately does it and it took awhile to realize what was going on, its most noticeable with cruise on coasting down a slight decline around 60 kph, it will accelerate (going down hill) just a bit to a speed which is above the set speed (60) then go off throttle, that causes DFCO to kick in, it decellerates to a speed just below the set speed and wants to speed up so DFCO is cancelled, fuel flows again and car speeds up to set speed at which point with the engine running it goes a bit over the set speed and DFCO cuts off fuel. The process continues until either the hill gets steep enough that it can stay in DFCO at or above the set speed or I get in the flats and the engine runs as normal.
Pretty subtle but you can "feel" it cut in and out.
kenora is offline   Reply With Quote
Old 06-24-2009, 11:57 AM   #3
bronsin
bronsin's Avatar
Whenever you're coasting with the engine turning much above idle speed, the fuel is completely cut off for zero emissions and zero fuel consumption.
If that were true the engine would stop running. The engine has to have fuel to idle. But what you say is interesting. I had a BMW F650 2001 which, at times, would not idle when you came to stop at a light. It would start and run if you gave it more throttle while cranking, but it would not idle if you relaxed the throttle to the idle position. Turn the ignition off and on, start the engine and poof, it ran flawlessly. Until the next time. I could not fix it and neither could BMW. (their main effort was to blame me for not pulling the clutch in in time)
But maybe it had something similiar to what you describe. Thats the problem with all this gee whiz neato stuff. When it breaks its pretty hard (if not impossible) to fix. Some say they dont notice this problem so maybe theirs is working properly.
Old 06-24-2009, 12:27 PM   #4
Yaris Hilton
Smile
Not at all. It's engaged to the driveline and is kept turning by the car's momentum. Indeed, if you turn the switch off with the car in gear and moving, the engine will keep spinning till the car eventually stops.
DFCO is very common in modern automobiles.
The fuel cuts back in at idle power level when the engine speed gets down to some preset level just above idle.
Old 06-24-2009, 12:45 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i'd like to add that this only happens on decel (per my wideband o2 anyway)
Originally Posted by xnamerxx
you nailed it sir.
Old 06-24-2009, 02:23 PM   #6
bronsin
bronsin's Avatar
Hmm you said "turn the (ignition?) switch" off. I agree it would stop. But we're talking about taking your foot off the gas pedal and supposedly the fuel is cut off. If I took my foot of the gas of my Yaris it would slow down sure. But it would eventually go about 5 mph, not stop.
Old 06-23-2009, 07:19 PM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
7 seconds..???? he maybe be sleeping while posting this..lolz... stock yaris faster than mitsubishi ralliart or mazda3 gt .....hmmmm
Old 06-23-2009, 07:42 PM   #8
marcus
toyota
marcus's Avatar
i know for a fact that the Yaris bone stock with 17lbs wheels wrapped with 195/55/15 will do 10.1sec 0-100km/h. And i have data to back it up , search it or ask Thomas to shoot you the file
im aware of that..people even did 8.5 sec 0-60 mi/hr / 0-97 km/hr but 7 sec?? were talking about the guy who does 7 secs on a stock yaris 0-100km/hr ..must be going down hill..
Old 06-29-2009, 07:41 PM   #9
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Did I say I did 7 sec 0-60? NO. FOCUS. I said seven second range - so think 7.8 seconds. Tell me a good way to viddy the speedo and I'll prove it (or not ...)
Maybe tape the cam to your hat? It would shake too much with it attached to the pass seat I suppose. BTW I live just down the road from New England Dragway. I ran a '67 396 chevelle and a vega v8 in the late 70's. 0-100 in 12 seconds on the vega and the motor ran like crap. BTW new ralliart are heavy pigs. yea I am old - but prob not as old as Saildesign or YarisHilton
TheSilkySmooth is offline   Reply With Quote
Old 07-04-2009, 10:46 AM   #10
marcus
toyota
marcus's Avatar
well i got to see this.. u do 7.9 atleast on stock ill applaud you..,..and im always focused. its just you rattled me with ur 7 second range.lolz..but i really hope you can do it so i can say my car can do under 8 sec 0-97 kms per hr.
oh btw ralliart it an 05..great car to drive although torque spin is whats youll get most of the time..its a 7.5 sec 0-100km.
Old 06-24-2009, 11:50 AM   #11
hatchbackkid82
Drives: .
I really don't notice it
Old 06-24-2009, 12:20 PM   #12
marcus
toyota
marcus's Avatar
i-stop technology is coming in 2011..some cars in europe has it already.
Old 06-24-2009, 12:59 PM   #13
Actually, you're right. But in DFCO, the engine isn't "running" or idling, it's just spinning. There is no spark and no fuel during DFCO.
Tamago, the "D" stands for deceleration, so it's clear that's when it happens.
Old 06-24-2009, 01:21 PM   #14
Zaphod
Drives: Big Yellow
It's just compression braking with no fuel, as the drive train is turning the engine and pumping air through it.
What gear you're in determines the RPMs that your engine is running at, which determines how much air is being pumped through the engine, which is the resistance that slows the car down.
It's pretty easy to get used to judging distance and timing compression braking pretty much the same as you would with your friction brakes to the point that you use a lot less friction to slow down (and less gas with DFCO).
Honestly, I've noticed the lag with drive by wire more starting out in first on a hill. The workaround for me was to give it more acceleration earlier than I normally would with a manual transmission.
Zaphod is offline   Reply With Quote
Old 06-24-2009, 01:57 PM   #15
Tamago
Tamago's Avatar
Drives: ZZW30
and how does this work on an automatic? sounds highly inefficient as the engine revs will drop off, torque converter goes jellylike and now you have to build all of that energy back up to get the car moving again. i guess on a super long decel it would save fuel but otherwise not really ?
you nailed it sir.
Old 06-24-2009, 01:02 PM   #16
RedRide
RedRide's Avatar
I don't notice any throttle lag at all with my new Yaris with a manual tranny.
What was described in the original post seems like a defect IMO. It is not only anoying but, downright dangerous as well!
If it was me, I would go to the dealer and report the problem ASAP.
Not having access to 100% WOT on demand is a real problem as far as I'm concerened.
Perhaps as previouslty alluded to in other TBW threads, the less than 100% throttle is a setting for those who drive for economy while more aggresive settings are achieved for those who drive for performance?
I do know that my Celica (with a cable throttle) is set up in a simular way and will tune its self acording to your driving style. I frequently have to go for WOT, etc. otherwise, it will start to tune itself for more economy and less performance.
Old 06-24-2009, 02:31 PM   #17
bronsin
bronsin's Avatar
I agree! Unfortunately my wifes 05 Camry does the same thing. So we went through all this four years ago with the dealer. They couldnt fix it. I think it IS dangerous or at least undesireable. But you adapt to it I guess. The safety people could declare a recall but I doubt the company could do anything about it. Some claim their Yaris doesnt do this. Id like to try one out. If it didnt boy I would say the government should issue a recall notice. But in my experience the company couldnt fix it.
Old 06-24-2009, 02:04 PM   #18
sounds inefficient the way you describe it, but I'm sure Toyota considered options and built something for optimum mileage, don't you think?
Throttle lag and response yaris-me General Yaris / Vitz Discussion 19 05-20-2017 10:02 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 05:36 AM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
DIY: Crosspost of how to get rid of DBW Lag! Nexus1155 DIY / Maintenance / Service 7 09-14-2007 02:26 AM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 01:03 PM
