MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Header Wrap
I did header wrap on my e-bay stainless header two years ago and cut under hood temps. Pick up stainless steel tie-wraps from Harbor Freight to hold the insulation on your header. My critics predicted I'd burn through the header by now but it hasn't happened (yet).
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
I just did this, after finding this thread today.
$1.92 at Lowes for 6 feet of self-adhesive 3/4" Inside Diameter tube. $3.19 at Walmart for 200F duct tape (low quality, but will probably do). I don't have a temperature meter, but will say the effect on the a/c air was noticeable, but not extremely colder. I only covered the portions on the low pressure line (top) that were easily accessible (and straight), and will spend more time later to cover all the little spots... Thanks for this DIY! |
Also, holding my hand over the tube feeling the radiant heat from the exhaust, I don't see how it can end up burning or melting. Granted its a windy day, but immediately after shutting down from a drive, it wasn't too warm to touch.
![]() Drives: 2007 Toyota Yairs Join Date: Jul 2007
Welp, I made the video as planned yesterday, but immediately after doing so, I figured out a much better and less butt-ugly way to wrap the pipe; I redid it after work today without the camera running. So, I'll throw up a video/pic mix instead shortly.
Other.
That video was INTENSE!!!!
*shrug* Now it's gone.
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Texas. That explains it.
best DIY for summer season
![]() ![]() Drives: asd Join Date: Oct 2009
I did this mod recently and I can't say I really notice a difference. It might be cooler but if someone did this mod and didn't tell me I doubt I would ever notice.
toyota
this will keep me busy for a bit get my mind off other upgrade...cool..i meant that literally...lol
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." Last edited by marcus; 05-15-2011 at 10:25 AM. |
I've now had this mod for a year; a/c blows very cold, and begins blowing cold air almost instantly, much faster than without this mod. I had it on during winter, didn't run the a/c, but had no problems with air box freezing or anything like that. The tube wrapped in the heat resistant duck tape is holding up very well; no melting marks or dis-colorization.
Strong recommend!! |
advocatus diaboli
Well, since I'm off to home depot right now anyways I'm going to look at into this mod. If I do it I'll wrap the insulation in aluminum tape...
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Just reporting that I've done this and it does make a difference. The A/C feels a lot cooler and gets cool a lot quicker than before.
My g/f doesn't like it though she gets too cold now lol. |
![]() ![]() Drives: 08 Yaris S Sedan Join Date: Feb 2011
Just finished doing mine tonight actually
Got most of the line. Tried using this stuff and it was horrible So I ended up using the 97cent foam ones + metal tape. Last edited by jonathankoji; 06-07-2011 at 02:11 AM. |
Not quite a noob
I just wrapped mine. What I thought was a 1 man, 5 minute job tuned into a 2 man, 15 minute job. I used 1/2 in. wrap instead, it fit nicely when it was straight, but at the bends it was a pain. Some of the bends aren't fully wrapped, I couldn't get it all the way around. C'est le vie.
EDIT: And yes, JUST in time for summer! |
![]() ![]() Drives: 07 lb jeep tj Join Date: Oct 2010
Am I the only one who thinks the yaris a/c works very well even down here the florida humidity?
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| DIY Sound Insulation Guide? | qwerty123321 | DIY / Maintenance / Service | 4 | 02-07-2009 02:56 AM |
