#127 |
![]() ![]() Drives: 2008 Yaris Meteorite LB Join Date: Feb 2009
How you ever managed to get zip ties in the area near the alternator (picture 2) is beyond me! I tried and tried to do that, but couldn't get it done. Or, maybe my patience just ran out!
#128 |
SIPNDEW
#129 |
![]() Drives: Car Join Date: Nov 2008
#130 |
Now im trying to figure out if the cold line we are feeling on the top of the exhaust/left of the motor is actually going into the cabin, or coming out?
The pictures above show it coming out, meaning what is the point to keep something cool thats not going to the cabin to make us cool!? Someone has to explain this better, or maybe there is another place to insulate this? Also has anyone looked under the steering wheel, right side of the floor, and also seen how close the two pipes come to each other? Seems like that needs insulation as well! |
#131 |
Yes, that explination worked out great. Thanks.
I will try doing this tomorrow, couldn't today because I was in the process of installing fog lights. |
#132 | |
SIPNDEW
#133 |
evap core....
If anyone is concerned about the core freezing up....simply don't cover the entire line. It won't be as cold in the cabin, but you don't have to worry about it. If you covered the entire line, like I did, all you have to do is remove some of the insulation and the problem is solved.
#134 | |
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
DIY: A/C Insulation |
#135 |
#136 |
What does the dryer do?
#137 |
#138 |
So....I would assume that the dryer has some type of rating on it, meaning the amount of moisture it can remove out of the air in a given amount of time. With this new mod, more moisture will be present in the line. How do we know that the dryer will do it's job with the extra moisture. It might work for now, but a year from now, or 2, or 3, will it still be able to work correctly or will it break prematurely due to having to work harder?? Anyone have any longterm data?
#139 |
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
The drier will trap moisture and debris that entered the system when it was assembled and charged. As the a/c system is a sealed system you will not be getting any new moisture in the lines until a leak develops and then you have a whole new problem... no cooling. If you replace a compressor you change the drier too.
#140 | |
#141 |
It has the ability to absorb a significant amount of moisture - more than should be in the system from initial manufacturing. Once the system leaks enough to reach atmospheric pressure the dryer will most likely become saturated. Replacing the dryer, when replacing the compressor is important, since you can't easily tell the condition of the dryer and it is cheap in comparison to the compressor.
#142 | |
#143 |
When you charge an AC system, you first draw a vacuum on it to pull out as much moisture and particulate as possible. It's impossible to get every bit, so that's where the dryer comes into play.
#144 |
Thats why they need to have a removable dryer. Has a shut off valve before and after the dryer. After the dryer has done it's job, shut the valves off and remove the dryer. Clean the dryer out and reuse it on the next car coming down the belt.
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| DIY Sound Insulation Guide? | qwerty123321 | DIY / Maintenance / Service | 4 | 02-07-2009 02:56 AM |
