Old 08-01-2009, 09:17 AM   #1
Originally Posted by Sodium Duck View Post
So something like this will not work? Autozone Harness
Also, does anyone have the color codes for a liftback?
No, you would need this type, as you need to combine the tail, stop and turn lights together for the 4 pin trailer harness.
http://www.autozone.com/autozone/cat...questid=108197
For 07-08
On the taillight connectors (J3-Right, J4-Left):
Stop: J3,J4 - Pin5 (purple-LH side, orange-RH side)
Tail: J3,J4 - Pin 4 (green-LH side, gray-RH side)
Reverse: J3,J4-Pin1 (red LH-side, brown-RH side)
Ground: J3,J4-Pin6 (white w/black stripe)
Turn-Left: J4-Pin3-LH (green)
Turn-Right: J3-Pin3-RH (yellow)
For 09:
On the taillight connectors (J34-Right, J35-Left):
Stop: J34,J35 - Pin1 (purple-LH side, orange-RH side)
Tail: J34,J35 - Pin 4 (green-LH side, gray-RH side)
Reverse: J34,J35-Pin5 (red LH-side, brown-RH side)
Ground: J34,J35-Pin6 (white w/black stripe)
Turn-Left: J35-Pin2-LH (green)
Turn-Right: J34-Pin2-RH (yellow)
Old 04-24-2012, 04:31 PM   #2
marco2011
Drives: Toyota Yaris
For 07-08
Attachment 26764
For 09:
Attachment 26765
Im running in a problem!
I followed your diagram, and a strange thing happen!
Everything is working fine, but on the moment i put on the tail light on the car, the blinker (left) (right) go off!.
Im ussing the taillight converter
Toyota yaris 2006
marco2011 is offline   Reply With Quote
Old 04-24-2012, 04:40 PM   #3
Toyota yaris 2006
So, all of the functions work independently, but when both the tail lights and one of the blinkers are turned on, the blinker doesn't light, but the tail does?
Old 04-24-2012, 05:39 PM   #4
marco2011
Stupid me!
I bought a trailer-wire tester at canadian Tire (its a little plug what you can put into the 4-way plug car-side, what has little lets on it shows you the tail-light, and turning signals blink up on test). but but but, those test plugs dont work!!! i was already figuring for 1 day..how come how come it doesnt work!.
thyen decided to use a normal volt tester, and it just shows that it is working!
No Taiwan testers for me anymore
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
Small science fiction story I wrote which includes the Yaris. :) john21031 Off-topic / Other Cars / Everything else Discussions 3 11-21-2008 12:57 PM
hitch wiring hell twixt DIY / Maintenance / Service 9 06-02-2007 12:27 AM
Small Shift knob H8SGAS Items for Sale by private party 3 09-25-2006 07:28 PM
