Old 08-19-2009, 11:32 PM   #1
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
The trick to getting a cat into a carrier is to leave it lying about so that the cat gets used to seeing it. They will even go inside by themselves to explore after a while. That way they won't get alarmed when you put them inside (until you close the door ).
Amity looks like a sweetie.
Reddog99 is offline   Reply With Quote
Old 08-20-2009, 05:47 PM   #2
08YarisAZ
Drives: 08 Red Yaris LB
I've ordered a product called Auto Vaccine that is Chlorine Dioxide. It is a powder that comes in a cup that you add water to, and it produces a chlorine type gas that permeates all of the porous surfaces inside the car and eliminates all bacteria, mold, and mildew. Most smells come from the waste of those three things. I have not received it yet, but I will this weekend. Once you set it off, you have to leave the car alone for up to 12 hours. You cannot get in it while the product is working, as it causes respiratory damage. After the product has finished, you simply roll down the windows and air it out for several minutes. Then it is ok to drive. It is enviromentally friendly and approved by the EPA. Look it up using Google and come to your own conclusions. I am trying to elimate a moldy musty smell that started when I left a window down in a rain storm. I will get back and tell you how it went.
08YarisAZ is offline   Reply With Quote
Old 08-21-2009, 09:58 AM   #3
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
Did you remedy this problem yet? If not...
go rent yourself a rug doctor and use the attachment to steam clean n suck the dirt out of the area where your cat peed.
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 08-21-2009, 05:21 PM   #4
tomato
tomato's Avatar
I don't hate cats but I get along much better with dogs for some reason. They dig me, and I dig them. Woof. Every time I walk dwn the street and pass the coffee shop in my neighborhood, where people hang out with their dogs every week-end, it just makes my day.
I'm with Yaris Hilton. Generally, I don't trust / respect people who don't respect animals.
To the OP; how is the smell coming along? Is it fading any yet?
Old 08-25-2009, 10:36 AM   #5
08YarisAZ
Well, I tried the Auto Vaccine product, and so far so good. I talked to the company and made sure I had complete instructions, which are also included with the kit. They recommended I do the process overnight, as the Chlorine Dioxide is less effective in sunlight. So I started the kit at 7:30 pm, and stopped it at 8:00 am the next day. It is a cup that you put a 1/4 inch of warm water in the bottom, then stand a packet up in the cup. You cannot be in the vehicle during the process. The next morning I got in the car, and it smelled like chlorine - like a swimming pool. I put the fan on recirc, no A/C, as the suggested, and ran it for a half an hour - just to make sure any mold or mildew in the A/C would be eliminated. Then at 8:00, I rolled down the windows, removed the cup, and threw it away, as the directions called for. Now it's into two days later, and the car still smells of chlorine. The smell will go away after a few days they told me, so I am waiting to give my final judgement. But, the seats no longer smell like mold, and that was what I was trying for. They also have a money back guarantee. They told me if the first treatment did not completely work, that they would send another kit free of charge. And if that kit did not work, they would refund my $24.95. So those are my results so far. They told me that the top three reasons that people order the product is for cigarette odor, skunk odor, and pet urine.
Old 08-25-2009, 11:12 AM   #6
MUSKOKA800
MUSKOKA800's Avatar
Call up your local crime scene clean-up guys. They're stench and stain removal specialists.
Old 08-25-2009, 10:25 PM   #7
I haven't seen an update on if you de-stinkified the seat yet, but I removed the passenger seat cushion from Crashy, when I took the seat apart to monkey with the occupant classification system. The cushion comes off fairly easily (there are a bunch of plastic clips along the bottom that hold the sides down). Once removed, the only part that is glued is the top surface (all four sides are free) and the top separates very easily from the foam.
Old 08-25-2009, 11:26 PM   #8
tomato
tomato's Avatar
So you mean, maybe she could just replace the foam, not the whole seat? you know that's really good info. I'm following the thread with interest because spilling things on seat can happen VERY EASILY.
Old 08-25-2009, 11:37 PM   #9
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
Why replace the foam? If you have the seat apart, then wash the fabric & the foam, maybe with detergent. Watch out for any electrical components. You wouldn't want to soak the weight sensors.
I've had a cat pee on a couch, and cleaned it by just hosing down the cushion foam & cover. In my case, I was able to do it while it was fresh (still wet), so I didn't even need any soap. I set both out in the sun to dry after squeezing out the water and everything was OK.
Old 08-26-2009, 01:31 AM   #10
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
fresh or not, i would have still used soap lol...
Old 08-26-2009, 08:04 PM   #11
yaris prime
Yes- I fit in it.
yaris prime's Avatar
Drives: 2007 Yaris liftback, MT
Maybe the cat was a Honda fan ?
Cat pee is tough. I have seen contractors have to remove carpet, padding AND the floorboards to get rid of it. Just when you think it is gone, you will get in your car on a hot day, and it will be back.
BTW, just because somebody hates cats doesn't mean they are mean to people, or other animals, or are destined to be serial killers. Come on people!
I'm surprised it doesn't have a pull-start !
yaris prime is offline   Reply With Quote
Old 08-26-2009, 08:13 PM   #12
tomato
tomato's Avatar
Hahahaha! Yeah, maybe he has something against foreign cars ;)
Hating cats is fine. It's a free country, lots of different opinions. Acting on it is probably not OK, though. I think that's all people are trying to say.
I think the posters saying "cat pees, cat out the window" were joking, at least I took it that way and had a laugh, but there were other threads where people mentioned that drivers would go out of their way on the road to kill whatever was crossing the road, for fun. that ain't cool
my 2 c! Peace
Old 08-27-2009, 12:07 AM   #13
JBougie
JBougie's Avatar
Unless anyone in here is this a-hole: http://www.twincities.com/stpaul/ci_...nclick_check=1, you've got nothing to worry about.
Also, I found this review on Amazon about Auto Vaccine ... so hey, if it worked for this guys fish scented Bently, why not a cat piss Yaris? lol
0 of 1 people found the following review helpful:
5.0 out of 5 stars Auto Vaccine is AMAZING!!!, January 27, 2009
By M. Manning - See all my reviews
(REAL NAME)
I am in the Classic Auto Upholstery Restoration business now for 30 years. I literally get some of the most rotten foul smelling cars on a regular basis. Auto Vaccine was recommended to me from a friend on the police force who uses it for their K9 transports. Since then I have used Biocide System's Auto Vaccine to successfully remove cigarette odor, mold and mildew odor, skunk odor, gas odor, and even upholstery glue odor.
I just received a $3000.00 tip from a very high profile client. I have customized seven cars for him. He brought in a brand new Bentley that I had customized three months back. He went on an overnight sailing trip. He accidentally left a window partly open when he parked his car at the Marina. Some kids thought it would be funny to through their fish caught off the dock into the window. When he got back there wear for rotting fish and fish guts all over the back passengers seat. This is now one of the worst smelling cars I have ever worked on. Luckily there was no discoloration on the leather seats but the smell was putrid.
He was expecting to have to completely reupholster the car but did not want to go through his insurance if at all possible. So he came to me for an estimate.
I felt very bad for him knowing how much he had just spent on the car. I asked him to leave the car for two days to see what I could do. It took two treatments of two Biocide System's Auto Vaccine. A grand total of four units and the car was odor free and completely decontaminated in less than 24 hours! AMAZING!!!
That is a grand total of $79.80 plus shipping. When he asked how much I told him it was on the house.
Needless to say I have a very happy and extremely loyal customer who wrote me a $3000.00 check on the spot as a token of thanks.
FYI
The police officer who recommended it to me suggested I only get it from SMM Distributors or directly from the Biocide Systems web site. They are the only ones carrying the "Biocide System's Auto Vaccine". The label on the pouch should say Biocide Systems on it and is silver. If it doesn't say Biocide Systems its not. It should also come with a money back guarantee.
If you are in the Auto detailing Biz or in need of eliminating odors or just sanitizing your car, I highly recommend this product. 5 stars all the way!!"
http://www.amazon.com/Biocide-System.../dp/B001H8VLFC
JBougie is offline   Reply With Quote
Old 08-27-2009, 04:27 PM   #14
tada
Drives: 2008 Red Yaris
(REAL NAME)
FYI
Hey,
I'm the original guy who mentioned the Auto Vaccine (aka 08YarisAZ), and I read that review and thought it was the biggest pile of garbage I had seen.
I contacted the firm, biocidesystems.com, and told them I had read this review on Amazon, along with two other reviews that didn't like it. One guy bought a 10 year old car with smoke odors, and the other guy bought one that the sunroof had leaked in. The guy with the smoke odor said it didn't work at all. The guy with the leak said that it did work partially, but he didn't want to spend another $25 for a second kit.
On their website, they have glowing reviews, and who wouldn't on their own sight? So I leveled with him about the lack of reviews for the product. I told them that I was very hesitant to even order it. But, I was sick of the smell, had tried too many things, and I was willing to try it. He said if it didn't work, to contact them and they would send me a second kit free. And if that didn't work, they would refund me the $24.95. The shipping cost of $7 is not refundable.
Now I do not work for them, or even care about them. I was trying to give the OP some help, and am even trying the product at my own expense. The review above is from some shill. No one would park a Bentley with the windows down and get a fish thrown in it. And no one would give a $3000 tip for getting a fish smell out. And I told the supplier that.
Now onto my results. I did the kit over Saturday night into Sunday morning. When it was done, it smelled like bleach. Now it is Thursday, and the bleach smell is subsiding. But, I do smell a trace of the "wet dog" odor coming from my seat cushions (the bottom half). It is not as bad, and it does have a trace of the Febreze that I used the day before I tried the kit. The Febreze odor will go away, but I don't think that the wet dog odor totally will.
So today, I am asking them for the money back or the second kit. The smell did lessen, and maybe another dose will get rid of it. There is a Canadian website that sells the same thing, and it recommends that you use two kits at once.
So that's my story on it.
And by the way, I have had a cat pee on carpet, in closets, etc, and none of the stuff available at Petsmart, Petco, Costco, Sams, Walmart, or anywhere has totally gotten rid of the odor. I have tried Nature's Miracle, Odoban, etc., and they do a good job for a period of time. But get the area wet again with water like from a carpet cleaner, and it comes back. Cat urine is the worst. I can get dog urine odor out, but cat urine has caused me to replace the carpet, the pad, and even take muratic acid to concrete slabs underneath the pad to finally get rid of the smell.
tada is offline   Reply With Quote
Old 08-27-2009, 04:37 PM   #15
tomato
tomato's Avatar
Originally Posted by tada View Post
Hey,
Well, I kind of agree with you there. That story is a little, hmm, I don't know, unbelievable.
Old 08-27-2009, 12:10 AM   #16
JBougie
JBougie's Avatar
Also, we use Natures Miracle from Petsmart in our carpet cleaner with regular carpet shampoo and it makes our carpet smell brand-freakin new again. We have a disabled dachshund that doesn't know when he uses the bathroom and when his belly bands slip off, we will have a trail of dachshund dribble down the carpet ... it isn't pleasant. The Natures Miracle has exceeded my expectations of a urine remover 110% becuase we have tried a LOT of products to try to keep from having to fork over our damage deposit/replace the carpet in our apartment.
Old 08-27-2009, 09:53 PM   #17
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
HELP! A turtle peed in my front seat!
Seems if you try to rescue a turtle hold him out the window...
Old 08-27-2009, 10:19 PM   #18
Oh yeah! A coworker of mine rescued a musk turtle one morning on the way to work and found out the hard way where their name came from. His Mazda 626 stunk for months.
Front seat modification. Increase thigh support. PetersRedYaris DIY / Maintenance / Service 36 08-22-2018 02:37 PM
front seat room Bigdaddy727705 General Yaris / Vitz Discussion 9 10-30-2013 12:26 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 04:30 PM
front seat removal/reinstall mark schofield DIY / Maintenance / Service 2 01-25-2009 08:29 PM
FS: Extra Set of Fat Cat Front Bumps Stops Galavoxx Items for Sale by private party 1 07-03-2007 09:58 PM
