Old 09-20-2009, 10:09 PM   #1
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
Somewhat disappointed
I just returned from a trip in which I logged 962.2 miles on 23.735 gallons of gas, for an overall average of 40.54 MPG. I was expecting higher MPG than that, since it was almost entirely Interstate cruising.
OK, tell me if you think I should have done better on MPG given these facts:
1. The car is an 09 Yaris sedan with auto tranny
2. I used the A/C all the time on this trip.
3. I keep my tires at the recommended cold inflation pressure and do not over-inflate to get higher MPG.
4. I had two 44 lb sacks of dog food that I picked up early in the trip in the back seat. (I would not be coming back through the town where the pet food shop was located during regular business hours, so I had to pick up the dog food at the front end of my trip and carry it around in the car for the rest of the trip.)
5. I used cruise control set for between 65 and 70 MPH, depending on where I was.
6. The car had about 7500 miles on it at the start of the trip.
So, do you guys think I got the MPG that I should have expected to get under the conditions as described above, or should I have gotten higher MPG?
I really thought that I would get 44 or 45 MPG.
Yes, I know I could have slowed down to 55 MPH and gotten way better gas mileage, and I could have done this or done that, but that is not the question. I'm only asking for opinions about whether or not I got the MPG I should have gotten for the conditions I have listed.
Tom
YarisOwnersDad is offline   Reply With Quote
Old 09-20-2009, 10:20 PM   #2
40mpg seems about right for highway at 32psi tire pressure + a/c
Old 09-20-2009, 10:22 PM   #3
tomato
tomato's Avatar
I think you got a pretty good MPG considering these conditions.
I get low to mid 30's (city driving though)
Old 09-20-2009, 11:22 PM   #4
BailOut
Steals terrorist's lunch
BailOut's Avatar
The dog food alone sucked away 1 MPG, so with the a/c, higher speed and lower tire pressure I'd say 40 MPG was normal.
- Brian
Share the Road
Old 09-20-2009, 11:36 PM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Yeah, 40 is about right for those conditions.
Old 09-21-2009, 01:33 AM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Sounds about right to me too. I did a 1700 mile (one way trip) this summer in an LB MT doing 75/80 with AC and averaged 35. I had hoped for more too but as you indicated 55/60 is the magic number for best MPG in the Yaris.
Old 09-21-2009, 02:05 AM   #7
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
that's not bad... id say wut u got is expected
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 09-21-2009, 02:06 AM   #8
kac
kac's Avatar
Drives: 2009 Meteorite 3dr
I agree with pretty much everyone else here. Shouldn't be dissapointed with those numbers at all. It's above EPA estimates so you should be happy with it. BUT if you're still dissapointed, drop some weight, add some air pressure, and slow down a little, then enjoy the gains. Rock On!
Old 09-21-2009, 02:10 AM   #9
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Seconded on all that.
Old 09-21-2009, 08:22 AM   #10
YarisOwnersDad
Thanks, Yaris Buds.
Obviously, I am not out to get every fraction of a mile out of a gallon of gas, or else I would slow down and would shun the use of the A/C. I want to get the best mileage I can get while driving the speed limit and using the A/C when it is needed.
I forgot to mention that for about half of those miles on that trip I had a 120 lb passenger, so I had about 200 lbs of extra weight, counting the two bags of dog food.
Thanks for your replies, Peeps.
Tom
Old 09-21-2009, 08:31 AM   #11
its surprising how much speed, weight, a/c and tire pressure make a difference in the yaris mileage sometimes...
mainly speed though (er, but i wouldnt know about a/c since i don't have it)
Old 09-21-2009, 09:58 AM   #12
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Identical to what I've observed also-hard to get great mpg over 60.
Driving on highway with AT, AC, tires at 44 psi and keeping to 65 mph I can only do about 42 at best. 55 I can get much better.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 09-21-2009, 10:08 AM   #13
Cosworth
Drives: S sedan
Tom
Well, it's probably about average. But, what kind of terrain did you drive the car? If it's going up a mountain and back, it's probably very good. But, if you drove on flat surface for ~960 miles, then you should've been able to do much better.
Cosworth is offline   Reply With Quote
Old 09-21-2009, 10:32 AM   #14
YarisOwnersDad
I meant to include the terrain as one of the conditions that I listed, but I forgot.
The terrain was about as flat as it gets. Most of those miles were in Illinois.
Tom
Old 09-21-2009, 12:34 PM   #15
advocate
Drives: car
Here's what I like to do: I turn on the AC to generate cold air and then after a minute or two turn it off. The air remains cold for about a minute and I turn it off when it becomes too warm. I wait as long as I can until the car becomes too hot to be comfortable again and then I turn the AC back on!
Also making sure the AC is cooling you off and not the needless parts of your Sedan will help. I would close the unused vents for sure, and the back ones if there are any (I drive a liftback so I don't know if the Sedan has rear AC vents).
Old 09-21-2009, 01:09 PM   #16
b_hickman11
Drives: 08 Sedan
Tom
what was the average outside air temp. during the trip?
b_hickman11 is offline   Reply With Quote
Old 09-21-2009, 01:27 PM   #17
YarisOwnersDad
Temps were probably 60°F for the lowest and 85°F for the highest. Most of my driving was done during the warmer part of the day, so I would guess the average would be close to 80°F.
Tom
Old 09-21-2009, 01:48 PM   #18
a/c on at 80F? you made of butter? lol
