Old 10-01-2009, 09:27 PM   #127
Originally Posted by ern-diz View Post
must...have...more...crashy...updates...
Very soon. Drywall work is done. Have to lay 200 sq ft of pavers this weekend, then it's back to Crashy. I've been doing some serious landscaping work around my place lately and it has me thinking that Crashy needs a dump bed.
Old 10-01-2009, 09:55 PM   #128
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Old 10-01-2009, 10:29 PM   #129
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
http://www.kmart.com/shc/s/p_10151_1...0070926x00003a
Wonder if you could hack that up and weld the frame into the rear. 80 bucks, but only like 20"X40"X10". Unless you want hydraulics (which you should lol).
Old 10-01-2009, 11:41 PM   #130
auxmike
auxmike's Avatar
I Crashy.....
Old 10-01-2009, 11:48 PM   #131
It's the right idea, but I would like it to be as big as possible. 40" x 60" would fit between the wheel wells and from behind the front seats to the rear bumper. Plastic would be a big plus for keeping the weight down.
Definitely need hydraulic dumping, even if it is manually pumped (i.e. $20 bottle jack).
Old 10-06-2009, 10:06 PM   #132
tomato
tomato's Avatar
Originally Posted by auxmike View Post
I Crashy.....
+1
Old 10-06-2009, 10:30 PM   #133
Sodium Duck
╚══════════RN
...so goodbye roof? Or would it not need to be raised that high?
Old 10-06-2009, 10:51 PM   #134
Roof's definitely getting clipped off. The outer pipes of the roll cage will follow the original lines from the bottom of the A pillars to the bottom of the C pillars. Cross pipes will go across the top of the non-existent windshield and in place of the B pillars. I want to keep the shape of the Yaris, but if I leave off the rear cross at the top of the hatch, I'll have plenty of clearance for the dump bed to lift.
I figure I can put a bimini top between the windshield bar and the B pillar bar to keep me dry if I'm plowing while it's raining or snowing.
Old 11-01-2009, 07:59 PM   #135
*MAD DOG*
*MAD DOG*'s Avatar
Any crashy updates, pics?
Old 11-01-2009, 08:52 PM   #136
No new pics, but I ordered my steel on Friday for the plow frame, roll cage, and brush guard. Next weekend is going to be a serious welding weekend.
Old 11-01-2009, 08:54 PM   #137
Sodium Duck
╚══════════RN
radical
Old 11-01-2009, 09:38 PM   #138
Morgan
Morgan's Avatar
Drives: 07 MM LB
don't get a welding sunburn! good luck :)
Old 11-01-2009, 09:49 PM   #139
I learned my lesson on that one. When i built my trailer I made the mistake of wearing a tshirt and welding gloves while stick welding 1/4 steel at 200 Amps. I ended up glowing red from 4" below my elbow to 4" above.
Old 11-01-2009, 10:50 PM   #140
tomato
tomato's Avatar
Right on!! We all wish we could be there to watch you work on Crashy
Be careful!
Old 11-01-2009, 11:48 PM   #141
wow, you can really get "sunburned" from a welding torch? I didn't know that!
Old 11-02-2009, 12:44 AM   #142
*MAD DOG*
*MAD DOG*'s Avatar
Well technically your not being burned by the sun, it's the white flame that's doing the damage.
Old 11-02-2009, 06:13 AM   #143
And, it's actually UV generated from the arc that burns your skin, like the sun or a tanning booth.
Old 11-05-2009, 09:22 PM   #144
I picked up a load of steel today - 2" square tubing for the plow frame and SAE 4130 1.500 x.095 tubing for the roll cage. It's going to be a weekend of molten metal for Crashy.
Winter Tires - For those who lives in Snowy Geography jmharn General Yaris / Vitz Discussion 1 10-01-2007 09:36 AM
