#1 | |
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
#2 | |
![]() ![]() ![]() ![]() Drives: 08 BB LB Join Date: Dec 2008
Looking at a few things it seems that the intake manifold is interchangeable, along with the cams. But if you change the cams you may want to see if you can find pistons that have correct dimples in them or are short enough to clear the valves. It also seems that most ls headers are interchangeable as long as they clear the inner fender and the firewall. The heads also swap over, which will give you a lower compression ratio, which in turn is good for boost. |
ding ding. That's what I wanted to hear :)
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Research is a good friend. I found all that on google books. The book said that if you swap LM7 heads on a LS1 it will raise the compression so the opposite must be true because the LS1 heads have a bigger combustion chamber.
| Where to find block heater cable that was factory installed? | D6U4 | General Yaris / Vitz Discussion | 5 | 12-16-2008 08:04 AM |
