HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Grounding kits
I have two grounding kits available two different styles.
One is battery mount ground plate kit One is firewall mount ground plate kit Both are made from 8 awg high quality power/ground cable, with gold ring terminals. Wires are transparent black and are complete/made to fit. The gold ring terminals are made by Monster. Kit comes with everything needed to install the kit including the ground plate and mounting hardware, bolts to attach wires to ground points etc. May also be available in silver as I have silver wire on order. $21 each to US or Canada, shipping is included. Battery mount kit ![]() ![]() ![]() -------------------------------------------------------------------------- Firewall mount kit ![]() ![]()
The early bird gets the worm, but the second mouse gets the cheese. Last edited by 07WYarisRS; 12-09-2006 at 03:47 PM. |
ah nice, i might get one from you :)
this uses all stock bolts? |
![]() ![]() Drives: 07 yaris 5spd sdn Join Date: Aug 2006
PM Sent.
#4 | |
HardlyDangerous
The firewall unit it sold. I may have another one available later. If and when I di I will re-post it. I still have a battery mounted kit available. $21 These kits use some stock bolts as well as some stock pre-threaded mounting holes. The extra bolts and nuts that are needed I supply. The battery mount kit uses the stock battery post terminal. I will prvide the buyer with mounting instructions as well as color labled wires for easy no guessing, fast installation. If anyone wants extra cables for extra ground points just let me know what points you want to ground. The price will change slightly but not much. For instance added cables for the valve cover and A/C compressor etc the price will be $25
The early bird gets the worm, but the second mouse gets the cheese. |
HardlyDangerous
ALL SOLD OUT
For now anyway. When I get my spool of wire in I'll repost. The people that have already PMed me after the kits were sold out, you will be informed first. Thanks guys
payment sent
HardlyDangerous
I knew i should have bought that new Canon S3 IS
My digital cam sucks so this is the best you get for now I just poped the battery out of the car for installing my own kit. It makes it MUCH easier to get to the transmission and cylinder head bolts, but it can be done with out removing the battery. It only takes 60 seconds so why not... I also kept the OEM grounds in place with my firewall mounted kit. the wire all have an inch or tow of play so you can rout them different ways. The kits are test fitted to ensure they all reach and not too long to hang down onto any moving or hot parts. I also add a colored Zip ties to one end and instructions for where each whire was made for. If anyone has any questions onthe exact routing for each cable just ask ! For the cylinder head I removed a bolt holding a bracket on between the engine and battery. Sorry no pic of that one but you can use any bolt that attaches to the cylinder head. For the trans you can use the OE ground bolt or any other bolt that attaches to the trans. On the Auto trans just left of the OEm ground is a threaded 6mm hole where a second ground can be attached. For the throttle body I did not remove the actual throttle body bolt instead I remove one of the bolts on the metal throttle body bracket that colds the coolant hose in place. I has a metal bushing and makes a solid ground point with no risk of gasket damage or air leak by loosening the throttle body bolts. For the left and right chassis mounts I used the existing pre drilled/threaded holed on each strut tower. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
HardlyDangerous
Same ground points for the Battery mount kit
Here are a few pics of the Battery mount kit First remove the OEM battery terminal nut and cable using the supplied nut in the kit tighten it onto the battery terminal. this nut helps keep the stud tight and also acts as a spacer Then install the ground plate and the flange nut. IF you want to use the OEM cables you can just mount them on the rear most hole on the ground plate like in the pic and put one of the other cables on top. BTW ignore the little red wire, and rough looking ground plate I was using that to ground out the car so i did not have to reset the clock and radio stations while playing with the kits test fitting them. the gnarly ground plate is my test plate. The ones in the kit come polished with a bit of a shine ! ![]() ![]() ![]()
Can't wait to get my set! Everything looks nice and simple.
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
very nice, I'm gonna grab some more cable this weekend and add a couple more grounding points.
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
I just got my kit today.
Holy shit, 07WYarisRS! - This is some really nice quality stuff! Nice crimping work too. Assuming everything fits perfectly, this is a great value and a major time saver for me. The pics above will help immensely. Thanks! |
HardlyDangerous
Thanks
Glad to hear you are happy so far. Everything is double crimped and solid, let me know if you have any problems
HardlyDangerous
I have a battery mount grounding kit available
Made from 8 awg high quality power/ground cable, with gold ring terminals. Wires are transparent black and are complete/made to fit. The gold ring terminals are made by Monster. Kit comes with everything needed to install the kit including the ground plate and mounting hardware, bolts to attach wires to ground points etc. $21 each to US or Canada, shipping is included. Battery mount kit ![]() ![]()
#14 |
trying to make my own kit. i got like 100ft of #6 stranded wire with a nice thick rubber insulation. i think it's actually #6 welding wire or sumthing. I've got my heat shrink and my tie wraps as well but what for the terminals (stake on??) you use to crimp onto the end of the wire, i cant find anything that will fit #6 AWG. and for the circular plate, what kinda metal is that? aluminum?? will steel work?? like a cover plate for a electrical box?
#15 |
Got my kit the other day.
Everything looks nice, it was even packaged well! For $21 it's not even worth trying to one off a kit for your self. 07WYarisRS, great product. Thanks, Wayside |
#16 |
yea, but i got 100 ft of #6 wire for free!!
#17 | |
HardlyDangerous
Chances are you will have to buy then from a welding supply company or electrical supply company. 8awg terminals are too small Steel will work for a plate but will rust and corrode quickly with the moisture under the hood. It will need to be zink plated or galvenized steel. Copper or aluminum will work much better Like I said before in one of my other posts at $21 shipped for a kit, I'm not making $$$ on these things really when you factor in the costs of all the materials to make them. Aluminum, terminals, wire, shrink wrap (if used), all hardware, zip ties. not to mention the time it takes to make one and the shipping costs.
#18 | |
HardlyDangerous
Thank you Glad to hear you are happy... if you have any problems or questions let me know.
| u.s. model body kits? | delirium | Cosmetic Modifications (Exterior/Interior) | 27 | 09-07-2007 02:15 PM |
| Yaris Body Kits???? | SamSam | Cosmetic Modifications (Exterior/Interior) | 23 | 01-15-2007 03:38 PM |
| GROUNDING KIT DIY? | SEaton | DIY / Maintenance / Service | 73 | 10-22-2006 04:03 PM |
| Any lip kits out yet? | Spades | Cosmetic Modifications (Exterior/Interior) | 2 | 10-10-2006 03:28 AM |
| using regular power lock kits with cable style | twixt | DIY / Maintenance / Service | 4 | 08-12-2006 01:18 PM |
