![]() Whenever i go over bumps now my rear axle slams against this tie bar. I tried to sand down the horrible welds so it is pretty much smooth and even then there is still banging. Sadly i either have to take it off or put the axle back to the factory position =( |
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
5% Tint Rear | Micro Image LED Ignition Light Kit |
Are they? Yeah i dont think its possible really to install them upside down since they will function the same way still. But that could explain why i get some creaking noise occasionally while others do not with the same springs.
#4 | |
So, either both ways are fine, or one of you has them upside down ![]() The reason I brought it up is because I have similar looking springs, where the lower coils are closer together than the higher ones and I installed mine according to the DIY above. Also, the ends are not exactly the same, since one end gets a rubber cap and the other end sits in a groove on a plate on the axle. One end brings the coil almost to a circle, while the other kind of ends open. So at least from a geometry perspective, it's not the same. But it might be just fine... I don't know... that's what I'm trying to figure out
#5 | |
![]() going by this picture for tannabe it looks like the tightly coiled are supose to be on top since thats how the label is printed on the coil. |
#6 | |
#7 | |
JDM Fred
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 06:04 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
