View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 02-02-2010, 07:46 PM   #253
mick.wheelz
mick.wheelz's Avatar
Drives: 2006 NCP91R, 1991 ST184R
Send a message via MSN to mick.wheelz
There's not enough room behind the clock VFD on your cluster, but for US and Canadian clusters with tachs and digital clusters like yours, I am going to offer alterternative mounts as a single DIN plate (for those using a single DIN aftermarket radio) and a mount that replaces the left center A/C vent.
what gets in the way? is it just plastic or are there electronics there.... i dont mind hacking up some plastic LOL..
or is it possible to have one with a remote screen so to speak, eg. put the electronics in a box and have the screen itself plug in?
mick.wheelz is offline   Reply With Quote
Old 02-02-2010, 09:42 PM   #254
The circuit board is right behind it.
Old 02-02-2010, 10:48 PM   #255
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Ahh its just a circuit board hahahahahaha
Old 02-03-2010, 09:52 AM   #256
hatchbackkid82
Drives: .
I would not be surprised if i can't get a hold on one
hehe... when he's done! seriously though, there's going to be a rush on these I think...
Old 02-03-2010, 01:18 PM   #257
I'm hip!
Old 02-08-2010, 10:07 PM   #258
advocate
Drives: car
God I am waiting for this soooooooooooo bad
Old 02-09-2010, 12:15 AM   #259
I am supposed to receive the first 5 production PCB sets this week. If all is well with them I will let them cut the first production run (100 PCB sets). In the meantime I am working on wrapping up the firmware. I figured out how to get the cluster to tell me the raw reading of the fuel level sender, so the numeric fuel level / range until empty won't require a wire to be tapped. I am now working on getting the ECM to give up the air to fuel ratio.
Old 02-09-2010, 12:55 AM   #260
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
No words:
5% Tint Rear | Micro Image LED Ignition Light Kit
fmicle is offline   Reply With Quote
Old 02-09-2010, 01:30 PM   #261
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Scott, that left side vent mount will be perfect for me, especially in that orange RS glow with black backing...just installed RS trim pieces and a/c heater control knobs as well so black on black match.
Old 02-09-2010, 02:07 PM   #262
My understanding is that he can read memory addresses but would need the machine code to write to the ECM. Reverse engineering the machine code is problematic, and Toyota doesn't share it.
Have I got that right?
Old 02-09-2010, 02:26 PM   #263
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Whenever you start taking orders for this I have my $$ ready for you.
devinlamothe is offline   Reply With Quote
Old 02-09-2010, 02:52 PM   #264
That's correct.
I am making a bit more progress with being able to write to the ECM, for example I figured out the CAN message to make the ECM turn on/off the radiator fan at will.
For the question above about the AFR - The Yaris' O2 sensors are wide band zirconia sensors.
Old 02-09-2010, 04:07 PM   #265
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
i have a feeling this product will never come out, so many requests for more and more things to be adde, LOL I kid i kid.
Check out my Build thread:
Old 02-09-2010, 04:18 PM   #266
In the Engineering world we call it "feature creep". Marketing people love it (not) when we Engineers keep wanting to add just "one more little thing" before release...
Old 02-09-2010, 05:51 PM   #267
^ and building a website for a client is exactly like that too!
Old 02-09-2010, 06:19 PM   #268
POORSHA
POORSHA's Avatar
Drives: 2008 LB
And ordering take out is like that too
POORSHA is offline   Reply With Quote
Old 02-09-2010, 11:53 PM   #269
tk-421
tk-421's Avatar
Drives: 5D-07-LB
The best way to eliminate feature creep would be if the YarGauge were updatable via a serial connection... That would basically allow you to ship now and add features later on.
Then again, that would raise the final price for sure. Which I wouldn't mind doing BTW.
Old 02-10-2010, 12:11 AM   #270
The tricky part to that is that it consists of two separate processors, each of which requires a different interface for programming.
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 12:27 PM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 11:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 01:04 PM
