Old 02-19-2010, 04:20 PM   #18
Falconia
Drives: Yaris 1,3 -01 Linea Luna
That's correct. Your generation of Yaris had a different part number than the newer generation.
If simply disconnecting the module doesn't do the trick, then snap a picture of the connector. If the EWD that I have matches the wiring for your area, then I believe that you will need to disconnect the yellow wire (between the two greens) and leave the module in place.
Are you kidding me. I thought I solved the problem and I could start assemblying the kit when it arrives but you said that maybe disconnecting the module doesn't help?! Connector is blue colored, if it helps anything... What does it help if I disconnect just yellow wire but leave the module in place?
What EWD do you have?
Falconia is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
