Not quite a noob
Damn you're in ontario, I'd totally pay you to do this for me :P
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Good stuff . I have about a million questions for you, but here's a couple to start off with:1 Are the mounts in the same place on the C160? 2 Any mods required to the shifter cable ends or to the throw of the cables to prevent over selecting etc? 3 Why do you remove the neutral return spring? 4 When you change gear at redline in 1st, what revs does it drop to in 2nd? 5 Do you re-use the factory echo driveshafts? 6 Is the C160 diff an 8 bolt diff? 7 Did you have to re-shim anything? 8 Did you use any of the C150 bellhousing or casings or is it all C160 that's in there? I'll stop there for now.Cheers, Rob. |
#3 | |
2. You don't have to modify the cables, but you do need to play around with the angle at which neutral arm is on the transmission in order to be able to select all the gears. R is beside 1st. 3. Because of where neutral naturally fall between 3rd and 4th. With the spring in there it wants to pull neutral between 1st and 2nd. Not good when you pull out of 5th looking for 4th and you get 2nd instead. ![]() 4. I haven't really checked yet, but it somewhere in the area of 4600-4800. (I'm eventually going to make a video pulling onto the hyw so I can see what the RPMs are actually doing.) 5. Yes. 6. Yes. Prime for various LSDs. 7. No. 8. Yes, the entire C150 Bell Housing is used. The only swap is to the reverse arm and shafts pictured. The rest is C160. They both mate together perfectly with locating dowels. I think this would be killer in the rally car. But you'd definitely want to find one with an LSD. |
That's what I'm thinking. I already have this sitting at home waiting for the right gearbox to put it in.
#6 | |
I was kinda pressed for time as I needed my car. The only problem there seems to be is with 4th gear when the transmission is still cold. I think the syncro is a little rooted. Once it warms up it shifts much better. Also, it doesn't grind or anything, even when shifting hard @ redline. It just has a click when you pull it into gear and a slight vibration in the shifter. But in your case, if you have the time to work on both transmissions out of the car it would be a really good idea to go over EVERYTHING, like a rebuild should be done. |
| Tags |
| 6 speed, conversion, gearbox, transmission |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
