Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Good stuff . I have about a million questions for you, but here's a couple to start off with:1 Are the mounts in the same place on the C160? 2 Any mods required to the shifter cable ends or to the throw of the cables to prevent over selecting etc? 3 Why do you remove the neutral return spring? 4 When you change gear at redline in 1st, what revs does it drop to in 2nd? 5 Do you re-use the factory echo driveshafts? 6 Is the C160 diff an 8 bolt diff? 7 Did you have to re-shim anything? 8 Did you use any of the C150 bellhousing or casings or is it all C160 that's in there? I'll stop there for now.Cheers, Rob. |
| Tags |
| 6 speed, conversion, gearbox, transmission |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
