Old 04-20-2010, 07:29 PM   #1
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
Shock/Strut installation, how many hrs?
How long does it take for a skilled mechanic to replace shock/strut on my yaris?
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 04-20-2010, 08:56 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I'd say 2-3? Mine took about that
Old 04-20-2010, 11:25 PM   #3
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
40 minutes.
and we took our time. this includes taking off the wiper cowl
Old 04-21-2010, 09:42 AM   #4
MUSKOKA800
MUSKOKA800's Avatar
It took me ~5 hours working on my own, taking my time.
Car on jack-stands in my driveway with the correct hand tools and a electic impact gun.
If I was to do it a second time I'd estimate 3 hours max.
Old 04-21-2010, 10:31 AM   #5
id say 2-3h as well
assuming you don't run into problems/seized bolts/nuts/etc
Old 04-21-2010, 10:36 AM   #6
The question is for a 'skilled mechanic'.
I would assume this means a trained technician, in a shop, with all appropriate tools. If that is the case, then job should take no more than 1.5 hrs.
Old 04-21-2010, 02:19 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
And folks here have stated that stealerships quote 4-5 hours.
Old 04-21-2010, 02:46 PM   #8
1stToyota
1stToyota's Avatar
I assume you're asking to see what the labor charge will be...Mitchell1 labor guide: roughly 3.2 hrs [front], 1.6 hrs [rear]...about 5 hrs, total
And I'd advise against going into a Service Center or Dealership, armed with the "I'll pay 2 hrs, tops" ...they'll most likely just laugh and say "do it yourself"
...OR, they may just hire you on the spot, if you can do f&r struts/shocks in that amount of time (1.5 to 2 hrs), guaranteed work, and with no mistakes
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-21-2010, 01:29 PM   #9
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
2 hours!
marlondog is offline   Reply With Quote
Old 04-21-2010, 01:37 PM   #10
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
A couple hours, tops.
Old 04-21-2010, 04:50 PM   #11
You'll have an easier time with the front struts. The rear shocks require removing a bunch of interior piece to gain access to the top nut.
Old 04-21-2010, 05:09 PM   #12
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Huh? It's been a while since I removed and misplaced mine, but isn't there just a pop-off cover over the top of the rear shocks?
To answer the question: 3-4 hours is reasonable for an experienced mechanic who isn't a Yaris expert. Any real shop is likely to charge you the 5-hour book rate.
None of this includes realigning the front. (no alignment required on the rear)
Old 04-21-2010, 05:19 PM   #13
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
I didn't even think I used spring compressors for this install for the fronts
Rears pop right in very easy, you should have no issues or waste time there, legit takes 10 mins after jacking it up properly.
Fronts youll have the issue with breaking the top nut loose, WEAR GLOVES, I didn't remove wiper cowl, just finagled myself in there, Fronts take a bit longer because stuff needs to come apart.
Read the DIY guide a couple times and it should take you with setup and prep under 2 hrs.
*Oh you're replacing the whole assembly and not just springs, might be easier for you then.
Old 04-21-2010, 05:29 PM   #14
From what I remember on when El Jefe helped me out, the only way he gained access to it was by removing a good portion of the rear interior. This is for the sedan folks, not for the LB folks. I know the LB has a cover that pops right off.
Old 04-21-2010, 05:29 PM   #15
darkmoon, are we talking about a liftback or a sedan?
The sedan is quite a bit different in the rear, the top of the shocks are not easily accessible as they are on the liftback.
The advice and estimates you're being given here depend on which Yaris we are talking about.
Old 04-21-2010, 05:30 PM   #16
Ah, ninja post me. hahahaha
Old 04-21-2010, 05:30 PM   #17
If you look at the answers so far, the LB people take only half the time as us sedan folks.
Old 04-21-2010, 06:56 PM   #18
Loren
What?
Loren's Avatar
The Yaris sedan doesn't exist in my world.
Yeah, I can see there would likely be a few interior panels to remove in the back of a sedan.
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 12:48 PM
Has anyone tried taping into the parking lights for fog light installation (safe?) YarisSedan DIY / Maintenance / Service 14 03-20-2010 05:49 AM
TRD springs - installation questions GrimlockGT Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 03-10-2010 11:12 AM
3Drive E-throttle (NTD/Shadow) With Installation ! micquek Items for Sale by private party 1 12-31-2009 07:21 PM
Yaris radio installation kit????????? Yarisguy13 Great Lakes 2 06-03-2007 10:24 PM
