![]() ![]() Drives: Flint Mica AT Sedan Join Date: Nov 2006
for non crazy drivers the rule of thumb is essentially that if u can get the stick into gear in the first place without forcing it, you're in a good place. anytime u feel it grind when u r trying to move it into gear means you're forcing it. as noted u may need to boost your rpms for it to slide in. but no, a double downshift isn't an insane thing to do, assuming you're being responsive to the tranny's feedback. i typically downshift from 4th to second around corners that i'm approaching at a decent clip. 3rd will do, but 2nd gives u the pull coming out of the turn and there's usuallly never any forcing of the gears. your tranny will let u know when it doesn't like what u r doing! ;) :)
#2 | |
![]() ![]() ![]() Drives: 07 5spd red Yaris HB 1.5L 16V Join Date: Oct 2006
![]() ![]() ![]() Drives: 07 Yaris Liftback Join Date: Aug 2006
If you're not using heal-toe to rev-match when downshifting, the actual process of downshifting for both speeding up or slowing down are executed in same manner. Once the shifting is completed, then you can speed up or slow down, but that's after the downshifting has been executed.
If you're not understanding (or it seems too simplistic), then I'd stay with the basic for awhile and just try to be smooth and keep the clutch burn to a minimum (meaning, avoid having the clutch partially engaged and accelerating while on the move). If you can do that and shift as smoothly as an automatic transmission, then the fancy stuff will be a piece of cake. Usually when a driver is referring to forcing the clutch, it means not giving the synchronizers enough time to equalize the engine speeds (which will put extra wear and tear on the syncs). To give the synchronizer time to do their job, it's better to shift slowly, but not slow enough to be jerky with the car (everything still should be smooth). In my case, when I'm on the boil, which is most of the time, I'm switching as fast as my hands can move. But it's a trade-off, and manual transmission are usually designed to be abused. But there so much they can take and if you're in-experience and forcing things (in general), you're going to quickly wear-out your transmission. Mis-shifting is the kind of stuff that'll cause all the nasty noises from the tranny and the only thing that can be done it that situation, is to go back down on the clutch as fast possible. Last edited by Pars; 01-08-2007 at 11:34 PM. |
#4 | ||
| Questions on pricing | littlecarlove | New YARIS Purchase Forum | 17 | 10-29-2006 07:53 PM |
| Questions, questions... | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 10-21-2006 01:42 PM |
| More questions | Buckethead | DIY / Maintenance / Service | 1 | 08-01-2006 12:46 AM |
| Newbie questions about the 2007 Yaris | urabus | General Yaris / Vitz Discussion | 11 | 07-06-2006 11:32 AM |
| new owner.. have questions | chibianh | General Yaris / Vitz Discussion | 8 | 05-14-2006 11:44 AM |
