![]() ![]() Drives: 1NZ-FE Join Date: Oct 2008
Roll center adjuster
Anyone on these? They are very pricey though.
Supposed to lower the roll center after u lowered your car. Reduce roll during cornering. |
Perhaps you could put a link up to what they are and what they do. I've never heard of them.
At stock ride hight the arm is pointing slightly downward, not straight out. So unless you're more than 2" lowered, you shouldn't need something like that.
definitely more than 2". Any trackies comments?
![]() ![]() ![]() Drives: 2010 NCP91 5spd Join Date: Nov 2009
Based on the picture, wouldn't that piece just raise right back up to stock height?
Slowy getting there
They are not needed the Yaris has a feature likes this built in. Here is a whole thread on it: http://www.yarisworld.com/forums/showthread.php?t=23911 also here too http://www.microimageonline.com/foru...Suspension-Mod!!!!
#8 | |
I got it, BUT I am now talking about the front. Last edited by d1nzfe; 05-10-2010 at 06:34 AM. |
Yes, and the built in feature moves the appropriate pivot point. This mod only adds more length to the strut, which defeats the (cosmetic) point of lowering a car. This would be great if all you wanted was to stiffen the suspension, without lowering the ride height. . . which is actually something I am interested in (ground clearance is an issue here in Thailand), but I'd probably rather go with coilovers instead.
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
I think the main purpose of these is probably to correct alignment. I think some adjustable camber bolts, and you will be fine
The purpose is to adjust the angle of the lower FRONT control arm.
At stock ride hight, the arm is angled down slightly. When the suspension compresses in a corner the arm pushes out the bottom of the tire creating negative camber. If the arm is already straight out, it can only create positive camber as the suspension compresses. The diagrams in the 3rd post illustrates what happens pretty well. Remember that the strut will only allow up and down movement, but the control arm moves in a circular sweep. |
^ and to properly adjust the geometry, you would need to move the pivot point on the control arm, not adjust the length of the strut (which is what the blue piece does).
On a geometry standpoint, the picture is all wrong. . . but it's probably because a 3rd grader drew it on MS-Paint. There's really no point in me arguing about it. It's impossible to say what the heck it even does without a proper picture. |
now, we need somebody who actually know the picture here.
#14 | |
Roll center adjuster for honda Last edited by Bluevitz-rs; 05-11-2010 at 09:00 AM. |
#15 |
No need to be rude. Thanks for the pic. Is that the same exact piece?
#16 |
Apexing Egg!!
they even make them for the vitz! http://www.nengun.com/moonface/front...r-adjuster-pro
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#17 |
Same idea. If you could get the stock ball joint out and replace it with a longer one, you regain the slight downward angle of the control arm. You technically should have one for the tie rod too to prevent bump-steer.
#18 |
its is available for vitz thats y i asked..
| Rear suspension | Maitre_Te_Te | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 257 | 03-30-2021 10:05 AM |
| center caps for 15" steelies? | Lewis | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 07-02-2018 02:50 PM |
| Ignition vs. Roll start? | Alypuppy | Fuel Economy Forum | 53 | 05-18-2010 10:51 PM |
| TOYOTA center caps and Trim Rings for sale. | coffiend | Items for Sale by private party | 10 | 05-11-2010 06:29 PM |
| My $7 Interior Upgrade - Center Heater Vents | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 54 | 05-18-2009 08:51 AM |
