Old 06-20-2010, 06:19 PM   #1
kou
Drives: 08 lb
THROTTLE BODY SWAP NO CEL!!!!
So i did the swap without getting a cel ever. THANK YOU jkuchta for the info.I ordered a new intake manifold, a yaris and a corrola throttle body.Step one was to fill in all the cavaties on the manifold with JB weld then port the opening as much as i could. swapped the chips over on the throttle bodies and removed the epoxy from the idle adjustment screw,then switched everthing over, did a pre adjustment on the idle screw and made a paper gasket which is siliconed in place.
Old 06-20-2010, 06:31 PM   #2
how much were you able to open up the stock manifold?
Old 06-20-2010, 06:36 PM   #3
kou
Drives: 08 lb
I ported the top to about 2.4" then i tappered down as much as i could, the plastic is thinner the further you go.the factory opening is 1.75".
Old 06-20-2010, 06:49 PM   #4
not too shabby
notice a difference then?
Old 06-20-2010, 07:15 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Nice and clean. Very good job!
I opted for a custom adapter instead of porting the IM. How much did the IM cost? Just curious.
Old 06-20-2010, 07:15 PM   #6
kou
Drives: 08 lb
There is a difference at all rpms but more after 2250rpms.more engine power with the ac on which is a big plus. my ASStermater says more tourqe than hp.definetly worth the $250 in total spent.
Old 06-20-2010, 07:16 PM   #7
kou
Drives: 08 lb
Thanks tk-421.manifold cost $113
Old 06-20-2010, 08:08 PM   #8
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Wow that is nice
this is one Mod i would love too do , but am affraid to do as it might not
be as simple on the 2NZ-FE.
Enjoy and congrates
Old 06-20-2010, 08:13 PM   #9
Wow that is nice
Enjoy and congrates
should be the same...only different item on the 2nz is the pistons/rods (and therefore the displacement)?
Old 06-20-2010, 09:05 PM   #10
kou
Drives: 08 lb
Wow that is nice
Enjoy and congrates
Thanks i am enjoying ever minute.
Old 06-20-2010, 10:50 PM   #11
nicely done. I've always thought that this mod, done carefully, is a good one.
Old 06-20-2010, 11:40 PM   #12
kou
Drives: 08 lb
Thanks, definitely can't rush this one.
Old 06-21-2010, 11:26 AM   #13
d1nzfe
Drives: 1NZ-FE
what do u fill up those 'holes' with? the purpose to 'strengthen' the frame for porting?
d1nzfe is offline   Reply With Quote
Old 06-21-2010, 12:34 PM   #14
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
NICE WORK, very good thinking on how to get it done, as long as you let the JBWeld cure and it stays that is a nice for DIYers. Just hope nothing ever happens where a chunk might come off of that and go into the engine
Old 06-21-2010, 01:49 PM   #15
kou
Drives: 08 lb
Thanks Nexus.I am not to worried about the JB weld it's now a solid ring.Any way if something did happen engines are pretty cheap.
Old 06-21-2010, 01:54 PM   #16
kou
Drives: 08 lb
I used JBweld the slow curing type.Mainly to make a flat mating surface for the throttle body.Because of the intake manifold design after porting you have to put JBweld on the inside to get a smoother slope.
Old 06-22-2010, 01:33 PM   #17
Nexus1155
Drives: Audi
Drive a full cycle, usually 80miles on most ECU's and let us know if there are any CEL then? I would love to do this.
Old 06-22-2010, 02:06 PM   #18
YarisSedan
Drives: 08 Yaris Sedan
Wow very nice. If your gona do something do it right. For the price of the intake manifold its not that bad.
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 06:20 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 06:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 09:52 PM
DIY: Tricking ECU Throttle Body Relearning gwasabi DIY / Maintenance / Service 2 04-03-2009 08:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-02-2007 12:38 AM
