#1 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
3000 miles change is an old recommendation when engines and oil formulas were built to less exacting standards. that crap doesn't apply anymore, but oil change places put the fear into you so they make more loot follow the owners manual. if you use mobil 1 go to 10,000 miles before oil change |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
This.
Oil is a precious and limited natural resource, and people are pouring it away because of some outdated information. Luckily some of it can be recycled, but it would be better to use it to its maximum extent than to needlessly change it because of ignorance!
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
Well said! And there are "extended performance" blends out there that let you go all the way to 15k miles between drain intervals. I've been doing this along with a high performance filter since the first change and things are running fine at 65k miles. I have yet to find any metal on the magnetic drain plug.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
"Gettin Jiggy wit it"
5000 mile oil change
5000 miles on an oil change, it depends on how much you love your car. Yes todays engines are better built then long ago, I was a mechanic then and still am. I also worked in an oil testing facility in the military. There is more break down of the oil the longer you use it, except synthetic oil. Toyota does not make any money from you by having engines last 500,000 miles. They want the engines to wear out sooner so they make more money. I did my first oil change on my "S" liftback at 1800 miles and my routine oil changes are at 2500 miles. Oil is cheap,engine work is not. Yes, you believe what you want to. Our 1.5 is a small motor that works hard and makes alot of heat. I have tested oil for many engines in a lab environment. Its science, not speculation.
#5 | |
Drives: 07 sedan Join Date: Mar 2010
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
Use Amsoil and go 15k miles.
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Dealer oil change | boggydee | DIY / Maintenance / Service | 16 | 06-30-2010 11:21 PM |
| Oil change time... yay! | YarisFan007 | DIY / Maintenance / Service | 10 | 09-19-2007 05:40 AM |
| Dealership wants $64.99 for Oil Change? | ScottFern | DIY / Maintenance / Service | 15 | 09-21-2006 10:49 AM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
