Old 07-18-2010, 04:47 PM   #11
sidewinder
"Gettin Jiggy wit it"
sidewinder's Avatar
Drives: 09 Yaris " S " Hatchback
5000 mile oil change
5000 miles on an oil change, it depends on how much you love your car. Yes todays engines are better built then long ago, I was a mechanic then and still am. I also worked in an oil testing facility in the military. There is more break down of the oil the longer you use it, except synthetic oil. Toyota does not make any money from you by having engines last 500,000 miles. They want the engines to wear out sooner so they make more money. I did my first oil change on my "S" liftback at 1800 miles and my routine oil changes are at 2500 miles. Oil is cheap,engine work is not. Yes, you believe what you want to. Our 1.5 is a small motor that works hard and makes alot of heat. I have tested oil for many engines in a lab environment. Its science, not speculation.
sidewinder is offline   Reply With Quote
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Dealer oil change boggydee DIY / Maintenance / Service 16 06-30-2010 11:21 PM
Oil change time... yay! YarisFan007 DIY / Maintenance / Service 10 09-19-2007 05:40 AM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 10:49 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
