Old 08-24-2010, 09:52 PM   #19
41magmag41
Drives: Loaded 2007 mica silver sedan
Originally Posted by rudolfoz View Post
I just went over 36 000 miles.
I guess it's too late.
I'll try the upside down filling technic.
I think you'll find the yaris has 60000 mile drivedrain warranty and the fuel delivery system is part of that. Also I think she has an 80000 mile warranty on the emissions end and fuel vapor recovery is under that. This item should still be a warranty issue.
41magmag41 is offline   Reply With Quote
Old 08-24-2010, 10:31 PM   #20
djct_watt
Drives: 2010 NCP91 5spd
If the problem persisted before the warranty ended, you may still be eligible to have it serviced by the dealer. It's ultimately up to the dealer's discretion, but they have funding for people who "make a fuss." Make enough noise, and they make take care of it. You have to be a PITA to the dealer though. . . sometimes being nice works, but in my experience, people fear the whip more than they want the honey.
djct_watt is offline   Reply With Quote
Old 08-24-2010, 10:34 PM   #21
djct_watt
could be related
http://www.toyotanation.com/forum/ar...p/t-57654.html
Old 08-28-2010, 01:08 AM   #22
rudolfoz
Drives: 08 Yaris Sedan AT
I tried today filling up with holding the nozzle at 45 degree angle. It helped. It was annoying to hold the handle while filling, but I will take that over spilling the gas on the side of my car.
Thank you for the help.
rudolfoz is offline   Reply With Quote
Old 08-28-2010, 02:30 AM   #23
djct_watt
if you do it at 180 degrees, you won't have to hold it. That's what I used to do (because I was lazy).
Old 08-28-2010, 06:09 PM   #24
Canuck
Drives: 07 5 door Hatchback
How did you fill up before? Were you using the gas cap to hold the filling nozzle open???
Canuck is offline   Reply With Quote
Old 08-29-2010, 12:25 AM   #25
rudolfoz
I am not sure what do you mean by "use the gas cap to hold the nozzle open"
I used to just put the nozzle in as far as it goes (which is not very far) and push the handle and "put on" the little lever to keep the gas flowing on its own.
Old 08-29-2010, 11:18 AM   #26
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
In Canada almost all gas stations have the autofill disabled, to get around this we wedge the fuel cap in under the lever to hold it on until it clicks off. Canuck may not be aware of the autofill capabilities of gas pumps.
Yarisduder is offline   Reply With Quote
Old 08-29-2010, 12:51 PM   #27
djct_watt
Wow. . . even in Thailand we have the auto-shutoff. . . what's all this fuuuusss really abooot?
Old 08-29-2010, 01:30 PM   #28
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
In some states in the US the auto-shutoff is disabled as well. Aimed at reducing spills where the feature doesn't work when the operator has walked away and left it unattended.
Old 08-29-2010, 11:04 PM   #29
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Also, filling slowly will result in spilling. Jam the nozzle in, and run it full blast. I have only spilled once, and that was from slow filling.
Old 09-06-2010, 03:17 AM   #30
birdman
Drives: '08 Blazing Blue Yaris LB
I never top it off. I always wait for the first click and no more.
birdman is offline   Reply With Quote
Old 04-17-2011, 04:01 PM   #31
Betherizie
Drives: 2008 4 dr Yaris
Unhappy ive had this same issue
I dont have a check engine light, I dont have a leak, I've held it every angle possible. I dont top off, It is getting worse and probably spits out a cup or two. It actually projects out though and causes a terrible mess. If your hand is on the pump you get gas all over your hands. Its terrible
Betherizie is offline   Reply With Quote
Old 11-15-2012, 01:51 PM   #32
cdilmore
Drives: 2010
41magmag41...
How did you resolve your "overflowing gas while filling" issue? When I picked up my 2010 Yaris from the dealer, she said: I just filled it. In fact, it overflowed.
I thought nothing of it until today - my first fill-up. Even with the nozzle completely inserted, the thing didn't trip & turn off. Just gushed gas right out the neck & down the car.
Thanks for letting me know if you changed your technique, or if Toyota performed a mechanical miracle. And thanks!
Chuck
cdilmore is offline   Reply With Quote
Old 04-09-2015, 09:31 PM   #33
ruslanus
Drives: 2012 Yaris
I realize this is an old thread, but my 2012 Yaris has the same problem. It doesn't matter how fast or slow I fill, or which gas station I use. Every time without a fail. I couldn't find a TSB for it. I was just wondering if the OP ever figured it out.
ruslanus is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Had problems filling the gas / petrol tank? fidgell General Yaris / Vitz Discussion 6 08-27-2010 04:47 PM
Filling up using spare gas tank. Yarimoto Fuel Economy Forum 5 08-19-2009 05:29 PM
Don't overfill your gas tank! kimona General Yaris / Vitz Discussion 19 07-17-2007 02:15 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
