#1 | |
![]() Drives: 2008 Yaris S Join Date: Oct 2010
#4 | |
Headlights (I have a low current neg headlight output) Door Triggers and type (have pos and neg trigger wires) Also have aux outputs for various things such as remote window roll up...would be great if I found where to tap the windows up. Oh, I have a Prestige APS-997N... |
#5 | |
Door triggers (negative input when door is open): FL-red wire 4A-21, FR-light blue wire 4A-24, RL-green wire 4A-5, RR-light blue wire 4A-20, Trunk/Hatch- Sky blue wire 4A-7 If the alarm only has one input for the 2 or 4 doors, you can tap all wires together. Auto window up/down module install: http://www.yarisworld.com/forums/sho...3&postcount=39 |
#6 | |
You are awesome! Thanks! Hopefully I can get these last few connections in tomorrow. |
#7 | |
All the wires match up except Green Pin 5 is Yellow on mine and There is nothing in Pin 20; there is a Blue in 19... With the windows...do I have to have this additional module? The way my manual reads it will do auto-up without any additional modules... Can I just tap the Up Motor wires on that chart? Also, something else I noticed, my horn is not sounding when it should with use of RS/Alarm. I tapped the wire under the column like your document said... It is negative switching right? I need to get you a 6-pack for all this help! |
#8 | |
Conn 4A 4B.jpg For the windows, you can use those same wires if your system has the auto roll up feature. Just make sure that it is rated for high current (20+A) or else you will need relays. For the horn, the black wire on the spiral cable connector is definitely it, and it is definitely negative switched. Check your tap to make sure it bit all the way in. |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 02:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 02:26 AM |
