Old 11-14-2010, 10:54 PM   #1
one down, one to go
got some time this afternoon while my daughter was napping in the car....finally put in one of the projector lenses in the oem yaris housing
went together relatively easy....
Old 11-14-2010, 11:27 PM   #2
severous01
very nice. i'd thought about it but the cut-off line from the factory is very smooth and looks awesome even with halogens.
Old 11-15-2010, 02:30 AM   #3
Tylermayer
Tylermayer's Avatar
Drives: 2007 Toyota Yaris
where do you get the halo
Tylermayer is offline   Reply With Quote
Old 11-15-2010, 05:41 PM   #4
i sell them (and HID kits and LED's)...
Old 11-16-2010, 03:35 AM   #5
yaris2010RS
yaris2010RS's Avatar
no now u can sell me mine and help with the install?
Old 11-16-2010, 12:51 PM   #6
sure, sending PM now...
Old 11-16-2010, 12:57 PM   #7
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Would you have a DIY? to share with Yaris World?
CLA 250, 4MATIC
Old 11-17-2010, 01:31 PM   #8
redglare45
redglare45's Avatar
Drives: 07 Sedan - 5 Speed Manual
Yes +1 on what Derick said.
How did you get them to sit "flush" towards the back of the housing? They look really good.
redglare45 is offline   Reply With Quote
Old 11-16-2010, 04:20 PM   #9
Hey Adam, is that the bolt-on projector kit? If so, I think you may have installed it incorrectly. The cut-off is going to be vertical instead of horizontal. I'm thinking this because of where the LED's for the halo is located. They should be at the bottom of the ring, but in your picture, they are facing to the left of the headlight.
Old 11-17-2010, 11:10 AM   #10
the bottom of the halo ring is pointing down
i actually installed them upside down to begin with just from taking the projector apart to look at it....
what i am doing to check the beam direction is shining an led flashlight i have thru the back of the lense....so its set up correctly, trust me.
you just have the orientation of the headlight wrong in your mind. the bottom of the headlight is the bottom left of the pic....
Old 11-18-2010, 02:39 AM   #11
My bad. lol, explained on MI. hahahaha. That angle just makes it look like a sedan headlight or a LB headlight laying on its side.
Old 11-18-2010, 08:12 PM   #12
no worries
Old 11-21-2010, 06:10 PM   #13
test fit the new projectors today
time to seal them up now....both work
Old 11-22-2010, 08:47 PM   #14
mrrock
Drives: yaris 2dr hatch
good job, are they a marked improvement over the stock light with better bulbs? how long did the whole job take you. do you sell and do the work.
only reason I ask is that I'm in St Clements several times a year
mrrock is offline   Reply With Quote
Old 11-22-2010, 11:37 PM   #15
ok, got a second wind tonight after a pb&j, so i sealed the lights up.....went together much easier than i expected.....the lenses just popped back into the clips without issue....i really though i was going to have to bungee cord the backs and fronts together.
Old 11-23-2010, 02:01 AM   #16
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Nice. Did you have to dremel the inside of the housing for the projector to fit?
Old 11-23-2010, 09:00 AM   #17
yes.
i had to cut off all of the brackets that normally hold the H4 bulb and bore out the hole a bit to fit the projector
Old 11-30-2010, 10:19 AM   #18
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Looks good, I'd like to get some projectors at some point but I'm afraid to commit lest I mess up something.
