![]() Drives: 2007 yaris sedan Join Date: Mar 2010
Hi Guys~
I have 2007 Sedan model also...the other day both parking brake and ABS lights came on then both went off inself after driving it about 30mins. A few days later those two lights came on again then went off itself...after reading up on these posts i went to check under the car (both rear speed sensor wires and connectors). After observing i did not see any chafed or broken wires and damage to connectors. After cleaning the connectors and sensor areas with contact cleaners and re-connected them back. I was fortunate to see no damage to wires or connectors. So far i don't see any problems with parking brake and ABS light. I think it's fixed for now~ P.S. I did check with OBD II but like the others peoples there was no fault code shown.(at least my case) I do not know why it did not record any fault code in computer?? |
#2 | |
Oh I C~~ thanks for the info CTScott.
FYI guys mine had 73,000Km right now |
By the way, you can actually read the DTCs using just a jumper wire:
With the ignition off, jump the CG and TC pins on the OBD connector: Turn the ignition on and watch the ABS light. If there are stored DTCs, It will flash in a pattern to indicate the code (71 for example will be shown as 7 quick flashes, a short pause, and then one quick flash). C1271/71 Low output signal of front speed sensor RH • Front speed sensor RH • Front speed sensor RH circuit • Sensor installation • Foreign matter on sensor tip or sensor rotor C1272/72 Low output signal of front speed sensor LH • Front speed sensor LH • Front speed sensor LH circuit • Sensor installation • Foreign matter on sensor tip or sensor rotor C1273/73 Low output signal of rear speed sensor RH • Skid control sensor RH • Skid control sensor RH circuit • Sensor installation C1274/74 Low output signal of rear speed sensor LH • Skid control sensor LH • Skid control sensor LH circuit • Sensor installation C1275/75 Abnormal change in output signal of front speed sensor RH • Front speed sensor RH • Front speed sensor RH circuit • Foreign matter on sensor tip or sensor rotor C1276/76 Abnormal change in output signal of front speed sensor LH • Front speed sensor LH • Front speed sensor LH circuit • Foreign matter on sensor tip or sensor rotor C1277/77 Abnormal change in output signal of rear speed sensor RH • Skid control sensor RH • Skid control sensor RH circuit C1278/78 Abnormal change in output signal of rear speed sensor LH • Skid control sensor LH • Skid control sensor LH circuit
#5 | |
DTCs checked today...
confirmed that i have 73. But there was also other lights were also blinked like transmission, airbag, P/S. etc what are these CTScott?? |
Jumping TC to CG does the same for those systems as well.
