Old 01-14-2011, 08:08 PM   #11
limochong
limochong's Avatar
Drives: 2007 yaris sedan
DTCs checked today...
By the way, you can actually read the DTCs using just a jumper wire:
With the ignition off, jump the CG and TC pins on the OBD connector:
Attachment 39321
Turn the ignition on and watch the ABS light. If there are stored DTCs, It will flash in a pattern to indicate the code (71 for example will be shown as 7 quick flashes, a short pause, and then one quick flash).
C1271/71 Low output signal of front speed sensor RH
• Front speed sensor RH
• Front speed sensor RH circuit
• Sensor installation
• Foreign matter on sensor tip or sensor rotor
C1272/72 Low output signal of front speed sensor LH
• Front speed sensor LH
• Front speed sensor LH circuit
C1273/73 Low output signal of rear speed sensor RH
• Skid control sensor RH
• Skid control sensor RH circuit
C1274/74 Low output signal of rear speed sensor LH
• Skid control sensor LH
• Skid control sensor LH circuit
C1275/75 Abnormal change in output signal of front speed
sensor RH
C1276/76 Abnormal change in output signal of front speed
sensor LH
C1277/77 Abnormal change in output signal of rear speed
sensor RH
C1278/78 Abnormal change in output signal of rear speed
sensor LH
Thanks to CTScott, checked my OBD connector and jumped those two pins
confirmed that i have 73.
But there was also other lights were also blinked like transmission, airbag, P/S. etc
what are these CTScott??
limochong is offline   Reply With Quote
