By the way, you can actually read the DTCs using just a jumper wire:
With the ignition off, jump the CG and TC pins on the OBD connector: Turn the ignition on and watch the ABS light. If there are stored DTCs, It will flash in a pattern to indicate the code (71 for example will be shown as 7 quick flashes, a short pause, and then one quick flash). C1271/71 Low output signal of front speed sensor RH • Front speed sensor RH • Front speed sensor RH circuit • Sensor installation • Foreign matter on sensor tip or sensor rotor C1272/72 Low output signal of front speed sensor LH • Front speed sensor LH • Front speed sensor LH circuit • Sensor installation • Foreign matter on sensor tip or sensor rotor C1273/73 Low output signal of rear speed sensor RH • Skid control sensor RH • Skid control sensor RH circuit • Sensor installation C1274/74 Low output signal of rear speed sensor LH • Skid control sensor LH • Skid control sensor LH circuit • Sensor installation C1275/75 Abnormal change in output signal of front speed sensor RH • Front speed sensor RH • Front speed sensor RH circuit • Foreign matter on sensor tip or sensor rotor C1276/76 Abnormal change in output signal of front speed sensor LH • Front speed sensor LH • Front speed sensor LH circuit • Foreign matter on sensor tip or sensor rotor C1277/77 Abnormal change in output signal of rear speed sensor RH • Skid control sensor RH • Skid control sensor RH circuit C1278/78 Abnormal change in output signal of rear speed sensor LH • Skid control sensor LH • Skid control sensor LH circuit
#2 | |
![]() Drives: 2007 yaris sedan Join Date: Mar 2010
DTCs checked today...
confirmed that i have 73. But there was also other lights were also blinked like transmission, airbag, P/S. etc what are these CTScott?? |
Jumping TC to CG does the same for those systems as well.
