Old 02-06-2011, 01:37 AM   #1
cool_beans00
Drives: 2004 Corolla
How important are hub centric rings?
And where can i get them if they are?
I'm looking into some Rota rims but they have a hub bore of 67.1mm and our is 57.1mm.
thanks in advance!
cool_beans00 is offline   Reply With Quote
Old 02-06-2011, 09:25 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
thanks in advance!
You could get lugnuts that self center. If you dont run either you are going to get some serious vibration as the wheel wont be centered on the hub. Eventually you will get slotting of the lugnut holes.
Old 02-06-2011, 10:52 PM   #3
severous01
i didnt think they sold lugs that werent centering. they all have the angled tip on them...unless you're just using any regular nuts you came across in the shop for emergency.
any way, if you're running lug nuts for aluminum wheels you wont 'need' centering rings. you will however need to re-torque the wheels after a fill up or two.
Old 02-06-2011, 11:16 PM   #4
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
The yaris hub is actually 54.1mm just like the miata. You could pick up rings from most tire shops. I got some gorilla hubcentric rings from amazon.
weedtank is offline   Reply With Quote
Old 02-06-2011, 11:18 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
discount tire direct sells hubcentric rings
but i run without them and my car doesn't vibrate (same hub dia) i have concluded after 2 years that they're a gimmick.
Originally Posted by xnamerxx
you nailed it sir.
Old 02-06-2011, 11:26 PM   #6
weedtank
I need more stars
weedtank's Avatar
Drives: Liftback
Also this
http://www.yarisworld.com/forums/showthread.php?t=26249
Old 02-07-2011, 02:22 PM   #7
cool_beans00
alright cool that makes sense. On my corolla I have the lug nuts that taper at the end.
Old 02-07-2011, 02:31 PM   #8
The lug nuts should match the hole in the wheel. Tapered to tapered, flat to flat...
dust to ashes.....
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 01:29 PM
FS: Mini Cooper to Yaris hub centering rings... DerFlosser Items for Sale by private party 2 03-27-2010 08:53 PM
what are centric rings gonzo452001 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-21-2010 02:52 PM
Hub Centric Rings HTM Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-19-2009 06:04 PM
hub centric rings & Exel wheel - what size Mead Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 08-02-2007 03:02 PM
